I've got a Gold Cube fuel flow transducer installed. Generally it's run well so far, but has required recalibrating at about the 50 hour mark after it started under-reading. Obviously under-reading is very undesirable because the fuel remaining in tanks (Totaliser) is lower than Calculated. I put this down to the transducer "running in", and recalibrated the K factor.
More recently it's been over-reading (safe but undesirable). But when I switch the electric fuel pump ON, after a brief initial increase it then settles to a lower and more accurate fuel flow.
In other words, if I ran with the electric fuel pump ON continuously, it would appear to be reading very accurately. Once I switch the pump off, it gradually returns to over-reading the fuel flow, and displaying a higher fuel fuel. So my thoughts are that this isn't related to the K factor.
Any ideas ?
Any ideas ?
