Good day builders,
I am finally back at building after moving to a new place. With all the new space I have finally opened up the engine box and took a closer look. I have to say seeing this thing really motivates me to get the "XHawk" in the air. Documentation is seems sparse and there are many things that I need to figure out. I hope you can help me answer some of the questions. I will also try to post all the details here as I go along.
I'll start with my specs:
- Bearhawk Patrol
- Lycoming YO-360-A1A
- 180 hp @ 2700 rpm
- Compression ratio 8.5:1
- Minimum fuel grade 91/96 avgas
- 95 octane Mogas adaptable
- Mount: Type I Dynafocal
- Crankcase style: Wide deck
- Alternator mount: boss mount
- Constant speed shaft and governor drive
- Governor location: rear mount
- Weight: 258 lbs
- Carburetor: Avstar 61C26047
- Fuel Pump: Aero 62A23701
- Magneto Left: Slick 66GC25SFNN (impulse)
- Magneto Right: Slick 66GP-0SANN (plain)
- Spark Plugs: Champion 1182-E7
- Starter: Hartzell 31A28861-Y (SKyTec 149-12XLT)
- Alternator (not included): B&C L-40
- Propeller governor (not included): Jihostroj P-920-032/A
- Hartzell Trailblazer (not included) HC-C2YR-1NX/NG8301-3X1
