Exterior Lighting
  • Exterior Lighting
    I'm deciding what to do with lighting. I'm building a 4 place and I want to be legal for night flying so I'm looking at Flyled's wing tip lighing. My issue is I'm not too keen on running wires to the rudder for a tail position light. There doesn't seem to be a great option for mounting a light on the rudder. I am wondering what other guys are doing for the rear position light. Flyled has a tail strobe/position light that would work great, but I see exposed wires crossing a constantly moving joint as a great way to cause a problem now or later. Maybe I am just overthinking this. What are others doing?
    I was also thinking that I could put the Flyled's wing tip lights on (both position, anti-collision and landing), a beacon on top and bottom in front of the tail, and for the rear position light, I could mount a rear facing white light in both wing tips. FAR 25.1385 allows that for the rear position light, but I'm not sure that applies to me. That would give me ease of access, no silliness of exposed moving wires, and hopefully meet the FAA requirements. Be easy on me as I'm new here.
    Rear facing white position lights go just fine on the wingtips. I like the one-piece position and strobe light LEDs. If you want to put a landing light in the wing, put it in the last outboard bay or the front corner of the wingtip. The nose is also an option.
      I put these on my wingtips... https://www.aircraftspruce.com/catal...powerburst.php
      They meet the rear visibility requirement so no tail light needed. (in Canada anyway). I don't have pictures of the lights installed but you can see the mounting location in the photo of the wingtips below.
      I put landing lights in the nose bowl to avoid having to deal with cutting up the leading edge of the wing.
      Both required a little fiberglass work but nothing too difficult.
      People I fly with always comment how easy it is to see me coming with the wig wag landing lights flashing. I leave them on all the time.
      IO-470 - 260hp
        We (I should say Carlo with me doing vertical head nod when I saw the install) went with rectangular landing lights on linear actuator... retracts or sits in preprogrammed (with an additional programmable module) or 'blipped' positions for takeoff, ID, landing, taxi, and underwing lighting (fewer LEDs running).with power and control running to wingtip, just as easy to pull wire for lights in last bay.
          I'm planning to use the FlyLEDs system exactly as you describe: Landing/taxi/position/strobe forward/side facing in the front of the wingtips. Aft-facing white LEDs on the trailing edge of each wingtip. The wingtips are still rough but here are a couple of photos. Be sure to talk to Paul at FlyLEDs to get guidance on how to properly connect the aft-facing lights to the controller. Each light needs its own ballast resistor. This configuration is not directly supported by the controller so a little bit of extra work is required to get equal currents to both aft-facing lights. DISCLAIMER: I'm not flying yet, still trying to figure out how to make the lenses for the big bays at the front of the wingtips. I've ruined plenty of acrylic sheets, but I've not given up yet!
          • carlpeterson
            carlpeterson commented
            I was planning to use the FlyLED system exactly as shown here but got hung up on the wording in FAR Part 91.205 (c) where it says the position and anti collision lights must be "approved". In FAR Part 1, the word "approved" is defined as approved by the FAA or someone they designate. From various sources I've gleaned the FAA will not approve these lights for the experimental world.
            My main concern is getting ramp-checked by some ambitious agent somewhere far from home after a night or IFR flight and having my aircraft grounded. If anyone on this forum has input on this I'd love to hear it.
          I went with nav/strobe lights all in one type. I can't remember the brand but there are several. Maybe aeroled. Easy install. Two lights to install, one on each wing. Each has on the forward portion the red or green, on the aft portion it has the white light and in the center is the strobe. I had my doubts at first about having the white light an inch from the colored light instead of on the tail, but it works and is legal. If I were doing more night flying at public airports I would probably install a beacon or strobe on the belly, just because I don't like to taxi around with the wingtip strobes on.
          Rollie VanDorn
          Findlay, OH
          Patrol Quick Build
            Dave Lenart just installed these on a Patrol and loves them. Thinking I will do the same.
            • rodsmith
              rodsmith commented
              If building now I would certainly go with those, looks like the solution for landing/taxi lights in a taildragger!
            • kestrel
              kestrel commented
              I'd like to see what a set of those look like when installed on a Five!
            Making/figuring the wing install brackets for them over the next weeks as well as a detailed write-up as I go. Will need two switches in the cockpit to control taxi light function and Paul@FlyLED has a single switch which can control/program landing and wig-wag functions.
              Given the airplane is certificated as part of the airworthiness inspection, those FlyLED lights would be 'approved' in the sense of the DAR that did the inspection signed off on the aircraft and systems as airworthy..
              • jaredyates
                jaredyates commented
                Personally I have no reservations about using non-TSO lights in a homebuilt, speaking both from the safety and compliance angles. I use AN bolts because Bob specs AN bolts for structural properties and manufacturing standards. I use aircraft oil because of the chemistry of our engines. But I'm happy to use automotive spark plugs because I think they are better. No judgement to folks who disagree, but I'm pretty particular about staying within the letter and intent of the regulations, and I think this is a non-problem.
              Agree - a youngster out of the OK school house might find some reason to write up a Normal category aircraft like a 172 with non-approved lighting system with a check of log books and the approved models list (plus 337's for the field approvals which are relatively common on GA aircraft), but that would be highly unlikely without an egregious violation (e.g., flashlights speed-taped to wingtips) or guidance from HQ or Region directing that specific inspection item. For E-AB, I have observed that the FAA's field force focuses on safety first, then compliance across specific installed systems where non-compliance or installation error are common (e.g., ADS-B installed/operational on aircraft that have flown into airports in rule airspace). Like Garmin's avionics lines that branch between Normal Cat (14 CFR Parts 23, 27) aircraft and E-AB, the lighting manufacturers seem intent on at least meeting minimum standards of those Parts while providing some enhancements to their current or planned STC or PMA stuff.
              In other words, I think there is reason to believe that - other than lighting which is clearly not fit for purpose from a non-aviation-focused vendor (e.g., Bubba and Bo's Underwater Fishing Lights as primary supplier for your homebuilt) - your use of a popular aviation manufacturer's lighting system on your homebuilt is unlikely to be as problematic on a ramp inspection at an airport inside the Mode C Veil as an absent or clearly inoperable ADS-B Out system. Also keep in mind that FAA operations and maintenance inspectors generally understand that there is stupid stuff and there is important stuff, and for a chronically understaffed field force, both senior management and line supervisors clearly skew towards emphasis on the later, if only to avoid explaining why they wasted their day on the former.
                I like your thought process and thanks for the input! I will definitely reconsider my "reservations" as I REALLY like the FlyLED setup!
                  [QUOTE=DBeaulieu;n92191]Making/figuring the wing install brackets for them over the next weeks as well as a detailed write-up as I go. Will need two switches in the cockpit to control taxi light function and Paul@FlyLED has a single switch which can control/program landing and wig-wag functions.
                  My aerosun landing lights have a built in wigwag function. I used an on-off-on toggle switch, up for landing lights, down for wigwag.
                    Dave, I’m stealing the other Dave’s thunder by posting this, but it should help.
                      500AGL Peter, what are my chances of getting in touch with this guy to see how he fabricated his cover lens for the wing. I'm interested if he may still have the mold or if he gently shaped an off the shelf lens from Vans
                        The lens is not difficult (and very satisfying) to make with a piece of Acrylic from the local hardware store and a heat gun, shaped around the leading edge.
