Anyone successfully mounted a set of these on the standard Patrol gear leg? The wheel fits fine but when I insert the brake caliper into the torque plate, the pins only go in about 50% of their length before the brake lining hits the brake disk. This is not good because the inserted length get's shorter as the brake linings wear. The Cleveland supplied drawing shows that the pins should insert their full length.
I could install a spacer on the axle to move the wheel out to provide the proper pin depth, but then there would not be enough axle thread left to install the wheel nut. Am I missing something?
Ron.
P131
Ron.
P131
