Seaplane version gross weight
  • Seaplane version gross weight
    Is there an increase in the Patrol gross weight if built with the modifications for the floats? The seaplane version.
    Scott Ahrens
    Bearhawk Patrol Plans Built
    #254
    I assume you are asking about the spec for max allowable gross weight due to float modifications to the fuselage tubing? I would think not, but i would be interested in hearing the answer from Mark or Bob
      Isn't there a 5% increase in gross weight for any airplane, only when it is on floats.
        I recommend you call Bob or Mark. The Four Place has been documented with an increase MGTOW form 2500 to 2700 with floats and I believe Bob approves something similar (a 200 lb. increase that is) for the Patrol.
        Stay updated with the latest Bearhawk Aircraft news and developments. Discover exciting updates and insights into our rugged and reliable aircraft models.
          As I understand it the 4 place on wheels has a MGTOW of 2700 but must land at 2500. That is quite a bit of fuel to burn off. When on floats takeoff and landing can be at 2700. I suspect this has to do with float fitting attach points location and load distribution than any structural or material changes. Certainly a question for Bob if it is an issue.
            I was in touch with Bob a short while ago about increasing to 2200#. My Patrol will be on amphibs this spring. Blessings were given on the increase for standard category only, not utility. I had to look that up. The root wing skins are .032 as the plans show. All other skins are .025 except for the outer two wraps. I have doors/windows both sides and the airframe was built with the mods at the lower sides stations B to D.
            Not sure south of the border, but there is a generalized rule of the mentioned increase of 5% rule in Canada. It was explained to me as being a stronger gear attachment allowing the increase over wheels.
              Good info...
              Steve - what amphibs are you planning on?
              Cheers
                Rebuilt damaged set of Wip 2100A’s.
                  Other than difference in G limits between utility and standard category, is there a difference in CG fore/aft limits with the GW increase to 2200?
                    There should not be.
