Brake Pedal Position
  • Brake Pedal Position
    Like an excited builder I mounted the seats and controls as soon as possible and took a quick mental flight to the sky. The ergonomics generally felt great. Only the brake pedals seem to be very steep. Is this typically something people adjust by shortening the extension rod? Or are the brakes used by repositioning the foot up and down?
    On all the airplanes I currently fly I can comfortably position the ball of the foot on the rudder pedal and the toes on the brake. I can select between rudder only, brakes only, rudder with brakes without repositioning my foot.
    To achieve this it seems to me the extension rod would have to be quite a bit shorter. Am I missing something?
    Stephan, mine is a 4-place Bravo so there may be some differences. However I just fine tuned my pedals yesterday because they were also too steep, and full brake meant the cylinders touched the firewall.
    It was very easy to do by changing the position the rudder cable attaches to the pedal. It pulled the pedal forward (towards the pilot), and the brake pedal went back (away from the pilot). Now it’s all quite ergonomic. I’m guessing you’ll find the same once you get the cables in place.
    • noema
      noema commented
      There seems to be a bit of adjustability but not nearly enough on the Patrol.
    You can just shorten the fitting that attaches the rod to the pedal. It took me a few tries to get it where I wanted it.
      Yes, on the Patrol & LSA it is common to shorten that aluminum clevis end piece to get the brake pedals at an angle/position you like. If the ends of the threads get a little messed up when you cut the piece - you can pass a tap through it to straighten up the threads. Mark
      • noema
        noema commented
        Good to know, simple enough. Thx.
      Curious as to what master cylinders your using. Wicks has a sale on right now. Cleveland CWB10-55, 8.750 installed length, 1.5" stroke. $250 each. I'm away from home so can't check my drawings to see if it's a possible match. Any opinions?
      Thx
      Patrol #30
        Brave move posting a photo of camo crocs
        • noema
          noema commented
          I thought you guys would understand.
          The struggle is real
        When you install and rig your rudder cables you can select a length that puts the brake pedals in a much more vertical position than you have shown. Here is how mine ended up.
        • noema
          noema commented
          That looks good, angle-wise. I certainly will have to chop a bit of the clevis pin to get it to this geometry.
          I chopped mine too.
