I have spent the last couple of weeks (or was is months) finding a definitive answer on wiring up the airplane. I just wanted to place a "simple" Steinair order. Turns out everything depends on everything. The kind of wire and length you need depends on where you place the component. Where to place the component depends on the type and brand of the component. The type of component depends on the kind of mission you are building for. Do I ever want to fly to Greenland?
Long story short I finally have come to a layout I am fairly happy with. I am posting it here with the intention to help future builders shortcut their journey. But I am also looking for feedback so I can further refine it. Please let me know if you see something that could be done better or should be changed.
Avionics Components
Avionics Components
- PFD - Garmin G5
- MFD/PFD2/EIS - Garmin GSU 460
- Sensor LRU - Garmin GSU 25C
- Magnetometer - Garmin GMU 11
- Temp Sensor - Garmin GTP 59
- Pitot/AoA - Garmin GAP 26 (heated, regulated)
- Engine LRU - Garmin GEA 25
- VHF Com - Trig TY-91
- VHF Antenna - Rami AV-17
- Transponder/ADS-B/LPV - Garmin GNX 375
- Transponder/ADS-B Antenna - Rami AV-74
- GPS Antenna: Garmin GA 35
- ELT - ACK-04
- Autopilot Servo - Garmin GSA 28
- Static Port - ACS 10-00250
- Battery - EarthX ETX-900
- Alternator - B & C L-40
- Starter (with YO-360-A1A) - SKyTec XLT
- NAV/ACL Lights - Whelen Blaze
- Taxi/Landing Lights - Baja S1 flush
- Stick - Tosten CS-4
