A question for those that are flying a 4-place BH. If you have a trim wheel like Bearhawk Aircraft sells with the small sprocket, how much do you move you trim wheel during a flight? When I say moving, how much of the 360 degree arc of the trim wheel do you use? I had the spec, but it got lost in a pile of email. If I remember right, someone once posted they only use about 1/8th travel out of the trim wheel arc during a normal flight. For example, flying a Cessna product like a C172 you turn the wheel quite a bit to get the indicator to move a little.
Trim Wheel Travel
I'm using about 1/4 travel with a fairly forward cg and 360 engine. Aft cg would theoretically reduce travel, while a larger engine and its associated higher top airspeed would probably require slightly more. I'm not especially happy with the current setup, and would like to have a system that is less sensitive.
Paul, those were concerns I had as well. Considering Maule, Champion, most Cessnas, and many others are set up with only one side, I'm thinking it is worth further exploration. With my lighter engine prop combo and being on the lower end of the power spectrum, the reduction of weight back there would be helpful as well.
Time to get back out there to work on it,
Mark J
For Bearhawks built from the older plans like mine that uses the longer elevator trim tabs. Use a Cessna trim jack screw that is in the stab of a Cessna 150-172. It has a 10-1 reduction ratio. There are Bearhawk flying with this mod and the trim is about like a C-172. I have drawing. The jack screw is mount vertical in the fuselage just ahead and below of the L.E of the fin . Dan R.You do not have permission to view this gallery.
This issue has been known for a long time, which is why I created a screw thread trim actuator as shown on the Bearhawk Reference CD. It seems like I once calculated that the reduction ratio was about 13:1. It's worked well for me. With 300 hours on Three Sigma now I'm quite used to it.Russ Erb
Bearhawk #164 "Three Sigma" (flying), Rosamond CA
http://bhcd.erbman.org
I forgot to look at you CD Russ. I just remembered the trim wheel being the same, so I assumed the trim system was per the "normal" system. I did consider the jackscrew Dan, but I didn't want all that chain. My son offered a few suggestions using a differential belcrank, but I think I have a good solution that is different than all these and much simpler. I'll post details when it's done.
