BearHawk 5 school of construction
" I have seen for the LS3 is a roughly 100-150lb more than the 0-540 " I have only one question. Where do you get your numbers from? Fairly big broad statement you made! Are you familiar with Lycoming 580 verse the 540? I am. I do not want to come across as being aggressive, However. You want to talk smack lets not start pulling numbers out of the air. A complete weight is not possible until a propeller has been decided upon. It is nice to see someone is paying attention to the pictures we post!Last edited by Sir Newton; 11-25-2021, 12:18 AM.
I’m really hoping that the Corsair power ls3 conversion is a success and well proven when I start my build in about 5 years. I love the LS3 and am rooting for anyone that is brave enough to try the conversion!
- Likes 4
That doesn't look like a Lycoming!
All joking aside, the auto conversions intrigue me. Did you go with an Autopsru or Robinson V8 drive? The installed weight I have seen for the LS3 is a roughly 100-150lb more than the 0-540 but I am wondering if it would affect the CG in a good way. I have read several reports of the 4-place running out of CG well before running out of gross weight and having more weight on the nose would help with that. Out of curiosity, have you run the numbers on the BH5 yet?
I have thought a 300-320HP turbo-normalized V6 may hit the sweet spot between power and installed weight but there really is not much on the market that fits in the category. I will likely have plenty of time to think about it while building and perhaps that niche will get filled in the meantime.
Keep up the posts! I have really appreciated the information you have shared!
- Bill
Leave a comment:
Greetings Bearhawkers! Just a quick check-in to say everything is going well with BH5 biuld. The biuld is getting a little western now! Been some crazy weather around some parts. Hope you all are doing well. CheersYou do not have permission to view this gallery.
- Likes 5
Leave a comment:
Going off book won't get you banned. It might get some pushback to help clarify that it is non standard. Grounds for banning include off topic partisan politics, toxic nastyness, etc.
I'd like to validate what Nev has written. Your a fabricator....you fabricators get stuff done....
Your scratch building faster than I can Quick Build and doing it right. We don't want design, strength, or safety compromises. I think Feathers get ruffled by compromises the erode best practices. You might consult with Jared about your off book ventures to see what the boundaries/allowances are and if your have some ideas that would benefit the design, streamline the build, or be a blessing to the group.
They look great, tight fit though. If I can do it again I would make them a tad smaller. Mine is exactly like yours
My post are going to be fewer & fewer, as I start to go off book with the project.
Leave a comment:
Some simple cheerleading about the BH5 project. Finished of fabricating 4 fuel tanks & all the tank strapping tighten turn buckles. Finished up fitting RH wing bottom skins. Recieved all my 4130 tubing. Fuselage fabrication will begin after I skin & rivet my LH wing. My post are going to be fewer & fewer, as I start to go off book with the project. Not wanting to russle feathers with the brass on the forum & get myself banned.You do not have permission to view this gallery.
This gallery has 4 photos.
- Likes 6
Leave a comment:
I want to share more information about layout & drilling caps strips with anyone who is reading these posts. It is very important when stack drilling multiple layers to make sure the entire stack is level. I am mean perfectly level use celecos to hold the caps strips assembly together. Drill in groups, front & back cap strips together lined up as they will be riveted on to the spar cap. Develop a system to keep track of which strip goes where! Keep your cutting tools & drill bits sharp. Doing this right means everything will line & your rivets will simply slide into the assembly with proper tolerances.
NCLSA183
I now understand you & your comment on this post commenting on AC-43.
Just some more cheerleading here. Finished welding out the RH main. For the welding nerds that read this post I averaged 1.7 inches per minute counting 2" per rivet on this tank. Just need to cut/weld in the appropriate sized NPT fittings and a bubble test & wammo finished RH tanks. Also got the fit up done on LH tanks this afternoon they still need the rivets bucked & then welding. Tuesday my 4130 tubing is arriving. I need to decide to finish off the riveting on the skins or to start fabricating the fuselage. 90% complete. 90%to go. Have good weekend.You do not have permission to view this gallery.
- Likes 7
Leave a comment:
Had a rain day today, I got out of doing fall yard work! I got to work on the BH all day. Awesome day. RH fuel cell all ready to weld up.You do not have permission to view this gallery.
- Likes 6
Leave a comment:
Leave a comment:
