Hello all,
I am new to this forum and Bearhawks in general. A quick biography to introduce myself; I'm from southern IL and live and fly from the family farm here on grass. I currently fly a Tri-Pacer and a Twin-Comanche, and I am not entirely familiar with Experimental aircraft or especially Bearhawks, so please forgive my ignorance(s).
I attend AirVenture every year, but my father and I have decided lately that we should consider some alternatives to our two current aircraft, so I was out browsing around last week, and came across the 4-place Bearhawk. We're trying to find something that would replace the two airplanes and be a good compromise for them. We spoke fairly extensively with Mark at the tent about this aircraft and some details, but I have several more questions in my search of different options. We're going to either have to spend a significant amount of money on our Twinco to get it back into good shape, or trade for something else. It needs engine and prop overhauls, a complete panel upgrade, and probably an autopilot or lots of expensive repairs to the Altimatic III.
I'm very keen on the idea of how much more affordable most parts seem to be for Experimental vs. Certified aircraft, especially the avionics.
I talked to two different companies at AirVenture about our options, and I came up with $25-35K for an awesome Garmin IFR panel and autopilot in an experimental, just FYI.
Now for the mission objective I'll be looking for out of our future aircraft: I want to be able to carry 4 passengers and 200# of baggage with the option of 5 passengers/less baggage with at least 5 hours of fuel, and have as fast of an airplane as practical. 95% of the flying will be in the Midwest on normal/long runways. So I don't care too much about awesome climb or super short takeoff/landings. I'm also open to other (affordable) aircraft suggestions, even though I know you're probably all partial to Bearhawks and Experimental. We restored the Tri-Pacer and won a Lindy at Airventure 2010, so the build should be no problem for us I believe.
I'm trying to decide on the engine model and prop combination that would suit us best, and what it's really going to cost to go this route, so any advice and actual figures are MUCH appreciated here. I'm leaning towards an IO-540 with 3 blade 62" Catto Prop.
I talked to Craig at Catto Propellers about this aircraft possibility, and I was quite surprised by his comments. He said that I would likely be happier with a fixed pitch cruise prop than I would be with a C/S prop. I'm a fan of the much lower cost, but I don't want to be disappointed with the performance. Although I'm much more concerned about cruise speed than I am with takeoff distance. And I really like the potential weight savings of a composite fixed pitch. He quoted 3,600 for 3 blade fixed pitch, and around 19,000 for C/S 3 blade! I'm curious what others have paid for a Hartzell C/S with the discount through Bearhawk?
Also, could someone provide me with some close numbers as to what I could expect with a cruise prop on the different HP options when cruising at 65-75% power and using the new "B" model wing?
What are some real life empty weights from you that have built a similarly equipped aircraft?
I would also like to hear some fuel flow figures from the different engines at 65-75% power. I'm planning to install an electronic ignition to increase efficiency, so please take that into account.
Last but not least, if you're not already overwhelmed with all of these questions, I'd appreciate any other tips and advice for a potential new owner of this aircraft.
Thank you in advance,
Zac Weidner
Zac Weidner
