Any updates on the problem with the brake master cylinders?
Safety Update Regarding Bob's Brake Master Cylinders in Dual Brake Applications
There has been steady progress getting this issue resolved. A fix has been designed and tested per Bob's instructions. All seems to work well now. A little additional testing will happen on a few more master cyls before we start machining the fix into all the master cyls. It has taken too long for me, but resolution of the problem is getting closer. Should be another month or two to complete the testing and get the needed machining done. Mark
Virgil:
Mark G. had posted in January that testing on Bob's brake master cylinder redesign was progressing. It has been several months and wondering if there continues to be progress and when parts or replacements will be available.Roger
QB Companion C-9
N51RK
Bearhawk Aircraft
