Any updates on the problem with the brake master cylinders?
Safety Update Regarding Bob's Brake Master Cylinders in Dual Brake Applications
There has been steady progress getting this issue resolved. A fix has been designed and tested per Bob's instructions. All seems to work well now. A little additional testing will happen on a few more master cyls before we start machining the fix into all the master cyls. It has taken too long for me, but resolution of the problem is getting closer. Should be another month or two to complete the testing and get the needed machining done. Mark
Virgil:
Mark G. had posted in January that testing on Bob's brake master cylinder redesign was progressing. It has been several months and wondering if there continues to be progress and when parts or replacements will be available.Roger
QB Companion C-9
N51RK
Roger, one feature of the forum is that you can tag members by starting with the "at" symbol and then typing their name. That will give them an extra notification to know you are talking to them. There's a good chance Virgil would see your reply but I'll tag him just to be sure he gets a notification.Originally posted by rkennell View PostVirgil:
Bearhawk Aircraft
Hey Guys, we have the final version of the cylinders here and are currently testing. All appears to be going well. We will begin the exchange process as soon as I have a stock of the new cylinders. I will be mailing you replacement cylinders with a return slip inside. You will simply put your old master cylinders in the box with the new label and send them back to me. If you have old cylinders or are owed a set of cylinders send an email to info@bearhawkaircraft.com with name, quantity of cylinders and address. We have an on going list, but never hurts to double check. Thanks everyone.
- Likes 7
