I'm working on setting my elevator travel on my 4-place. The up stop was welded in my the previous builder and stops the elevator at 27*. Cutting out the stop is doable but won't be a simple task. Will I miss that last 3* of travel?
Elevator Travel
Yeah, I got to thinking last night and wondered why I even asked this question; of course I want to get the full 30*. I must have been feeling lazy.
The stop needs to be moved 3/32" and I think I can come up with a solution that won't compromise any strength.
Thanks for the reply JimScratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
Originally posted by Av8rPaulI was wondering thinking about about your longer fuselage and if maybe the original owner purposely decreased the travel?Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
"Stretched fuselage"? Forgive me, since I've obviously missed something. Tell me more about the stretched fuselage. Or, refer me to a thread discussing such.
I see! One of my best buddies built a Bearhawk, several years ago. Before he sold it, I got several hours PIC in it. I was completely comfortable with the ground handling, but felt that it was just a bit pitch sensitive, at low speeds. Nothing terrible, mind you, so don't everyone start piling on about my criticism. Nicely balanced in cruise flight, but very light elevator when slow. When my buddy started talking about building another Bearhawk, I told him it would fly better (in my opinion) if it were a bit longer. Well, Ron is building another 4 place quick build and we understand that the airfoil shaped horizontal surfaces fixed the sensitivity. Or, maybe it was just me...
When I saw mention of yours being 'stretched', my first thought that you're going to have a great flying plane!
I would take the time to correct it to 30 degrees now rather than chance wishing you'd done it later. In forward C.G. flight you will want all the elevator you can get for 3-point full stall landings. I use all 30 degrees full up elevator every time with significant nose up trim unless I'm doing wheel landings...
Originally posted by Wayne Massey View PostI use all 30 degrees full up elevator every time with significant nose up trim unless I'm doing wheel landings...
Sounds like vortex generators under the Hstab are a good idea (at least on some).
Assembling the horizontal stabilizer and elevator…logged in today for the first time in…..years. Couldn’t recall the elevator deflection angles up and down… I’m way off.. loads down, didn’t bother to get the angle…but up is only 15 degrees… will have to move the up travel stop tube forward a bit to achieve to 30 degrees up… Don’t think my Pacer comes close to that which is why I went with the larger PA18 tail and VG’s on the bottom side of the horizontal stabilizers. It has gobbs of elevator authority even at forward CG with just me and no baggage….now if I can learn to see snow drifts when landing at night…grumble grumble…You do not have permission to view this gallery.
Originally posted by alaskabearhawk View PostThe control horn on the elevator is offset, it’s not a 90 deg angle to the spar. Do you maybe have it installed backwards? In other words flip the left elevator over to the right side?
