Jeff, can you elaborate how you used SendCutSend to do your panel for $40? Was it as simple as sending a dxf file, specifying the grade and thickness of aluminum, and it shows up on your door step? Would you be open to sharing your dxf file?
thanks!
John Hansen
Leavenworth, WA
Bearhawk 5 QB #63
IO-540-D4 with EFII System 32
That is exactly how it works. I used a dxf file that Virgil gave me as a starting point, then used Fusion 360 to design everything with CAD models downloaded from Garmin. Then sent SendCutSend the .step file of the panel.
N204jh here is the file used...
I also designed some custom brackets that combine the G3X frames with some rails to attach the center stack avionics rack. They did the two frames, and the panel for $140 with shipping.
I need the dwg of the 4-place panel as a starting place. I have been using Front Panel Designer (free, not aviation specific) with some success, but it can be limiting for some things, so I have started teaching myself Librecad to escape the walled garden. I have a hobby CNC that works well for wood cutouts and engraving, but I am not having success with aluminum on it. I use it for rough prototypes in thin sheets of mdf before committing a design.
