Rob, the first Amazon listing you linked (for the Baja Designs "backo-up light" unit) discusses the availability of several different combinations of lights (driving, combo, and flood), but offers no ability to select which one you want. The second Amazon link you sent is for Baja Designs "flood" lights, which their own literature says only lights to about 40 feet out, and is thus not suitable for "driving" (which I would think would also mean not suitable for flying).
I suspect you really want the "Combo" (spot/flood) version. It would be a good combination for both landing (spot = 9º beam angle) and driving (flood - 42º beam angle) lights for your Bearhawk. That "flood" patterns is probably a bit on the "wide side" for a taxi light (Baja doen't seem to offer a "trapeziodal" version – usually around 20-25º beam angle – that might be better for aviation taxi light usage. But that wider angle is probably great for recognition lighting in the daytime. Here's a link to an Amazon listing for the "combo" version of the Baja Design lights - no question about what you're actually getting:
Baja Designs Combo Lights
But to me, those prices are a little steep... (Or maybe I'm just a cheapskate!) One of the cool things about the Duckworth kit (thanks for that link, by the way) is that you can use a standard PAR-36 round landing light. Buy the $80 Duckworth kit (or one for each wing), add PAR-36
LED lights, and you can save a ton of money! And there are
lots of PAR-36 LED options out there, including Grimes, Wheelen, and other "aviation" vendors... But PAR-36 lights are available in both LED and incandescent forms from lots of online vendors. And nowadays, the LED versions aren't much more expensive than the "cheap, disposable incandescent bulbs" (as one aviation magazine refers to them...).
One of the non-aviation vendors I like is Larsen Lights. Their
PAR-36 Hi-Lo LED light is only $29, and offers both 20º spot and 40º trapezoidal beams in one physical unit. These lights produce 2830 total lumens (2200 effective lumens) with both circuits active. ("Effective" lumens is their measure of the light actually emitted in front of the lens of the light, rather than the total lumens produced by the LEDs themselves behind the lens. Most vendors don't give you both numbers, just the "total" number.) These are a LOT brighter than many of the PAR-36 offerings that are 4-5X the price...
I have a buddy who flies a lot of night flights because of his work. His airplane is a Rockwell Commander. He experimented with the Larsen Lights "PAR-36 Hi-Lo" LEDs as a direct replacement for both his landing and taxi lights. At first, it was just an "experiment" to see how they compared to the standard landing / taxi lights on his plane. He wired the "taxi" switch to the "Lo" connector, and the "landing" switch to the Hi connector, so he can control the two "sets" of LEDs separately. He absolutely
loved them, and they are now a permanent fixture on his plane. He says they are super-bright, offer a great beam pattern, and he recommends them to everyone who asks about his lights. And since his Commander lands a lot faster than a Bearhawk (Commander final approach is at 85-90 kts, touchdown speed around 65-70 kts), they should work really well for the much slower Bearhawk.
