Rookie question... I've completed the installation of my Hartzell Trailblazer CS Propeller. I followed the instructions in the Hartzell Manual. Tightened the nuts on the hub in a criss cross fashion, 1st pass at 40 ft lbs, 2nd pass at 60 ft lbs. All good there.
The manual calls for a "Air Charge Pressure Check", but explains little about the process. Anyone know about this?
The manual also discusses the initial operational test, but I find it odd that there is no detail about priming the hub with oil. And there is a CAUTION about "Air trapped in the propeller hydraulic system will cause the pitch control to be imprecise and may result in propeller surging". So.... How does oil reach the prop hydraulics initially? Especially on a new system such as mine that dry at the moment? (I have confirmed with Lycoming that my engine was set up for a constant speed propeller.)
Looking for more linear instructions pertaining the initial CS prop installation and operation.
