I wanted to share an idea I had and I been able to implement and I think it looks good. I am doing Kydex for a lot of the interior and figured it would make a good gear leg covering. A Kydex covered gear leg will take any rough backcountry landing you could toss at it.
I made a paper template and then cut it out in Kydex. I bent it with a heat gun from Harbor Freight. I used Nut Plates to seal the Kydex wrap up. At the top of the gear leg and on the backside.
I learned a few things about Kydex. First if you heated a area and put a clamp on it to keep it from moving it will leave indents. A bit of a "Duh" moment. Work the Kydex slow and don't force it. Kydex cuts easy with sheet metal tools.
I purchased 4'x8' .060 black Kydex sheets.
For some data the gear leg Kydex wrap weights 2lbs 2oz. More then fabric but way tougher.
