He did change the cable at the tab to exit the bottom instead of the top of the horizontal stab
Fixed Trim Tab vs Servoed Trim Tab
I bought Dan Riffee's project, and he had one of the earlier plan sets, with two elevator trim tabs. The work he did was excellent so I was hesitant to undo anything, however, when I rigged the controls with some temporary connections, I was surprised at the amount of servo action from the trim tabs. And it was not linear, changing from positive to negative servo action as the elevator is moved. As a result, I have removed the right-hand trim tab and am in the process of copying a Citabria's trim mechanism, which uses two control cables. I expect it to work very similar to Pat's.IMG_1771.JPG
Anyone know what kind of cable Pat used on his trim? I've been surfing around the Aircraft Spruce web site and can't find anything that resembles it. It kind of looks like Bowden cable with good quality threaded forks on the ends ....
Thanks
Maule M5-235C C-GJFK (Sold)
RV-8 C-GURV (Sold)
Thanks, Mark.Originally posted by Mark MoylePat used Morris control cables... Mcmaster-Carr is much cheaper than ACS. I don't have the part numbers on this iPad...
Unfortunately, I'll probably have to get them from ACS. McMaster-Carr refuses to ship anything to Canada. Not sure why, maybe the cold ? :-)
-29C here at home this morning, -40C with the wind chill.
Sent from my SM-G920W8 using Tapatalk
RV-8 C-GURV (Sold)
Those cables will be just fine, I think. Easy for me to say, I know...
My trim tabs have plenty of free play, over 3/8s at the trailing edge of the tab from memory. Maybe a lot more. This causes no problems whatsoever, they are not inclined to flutter.
You could add friction to damp the system if you are really concerned.
My latest YouTube video on a modified elevator trim system similar to Pat Fagan's: https://youtu.be/zJiWSkgq8kI
- Likes 4
Great job Paul!. I think this is a worthwhile mod but I don't have enough ambition to take it on. I did modify the original tabs to the smaller ones. My trim wheel is mounted on the floor next to the flap handle, seems more natural to me not to reach down for the flaps and then up for the trim wheel. Looks like you are making great progress.
Has anyone thought about using the old style, longer trim tab but just installing it on the right elevator instead of both elevators? That way you would only need one cable. One thing that may need to be considered is the stress that it may impose where the two elevators bolt together. May have to run this idea by Bob.
