Can anybody tell me the travel for the trim tab on the elevator thanks Wes
Trim tab travel
It will vary depending on how you set the trim tab horns up. Usually the tabs don't need to move far, not more than 10-15 degrees, certainly that's the most nose down trim you would ever need. But at odd times you need a lot of nose up trim.
The highest trim deflection happens with a STOL landing configuration, with the plane dead-light. That needs about 70% up elevator, which takes quite a lot of trim travel - perhaps 25 or 30 degrees. Although it's easier not to trim the whole way, and just hold a little extra back pressure.
When I am completely empty in this situation, landing as slow as possible, I run out of trim (and almost elevator) travel.Last edited by Battson; 11-17-2015, 05:41 PM.
[QUOTE=Battson;19167]It will vary depending on how you set the trim tab horns up. Usually the tabs don't need to move far, not more than 10-15 degrees, certainly that's the most nose down trim you would ever need. But at odd times you need a lot of nose up trim.
[QUOTE=Wes Helm Bearhawk 1209;19172]Thanks trying to make sure I had enough travel in my trim hingesOriginally posted by BattsonIt will vary depending on how you set the trim tab horns up. Usually the tabs don't need to move far, not more than 10-15 degrees, certainly that's the most nose down trim you would ever need. But at odd times you need a lot of nose up trim.
Whee's picture brought up a thought; when covering the horizontal stabilizer and trim tabs, take great care to minimize layers at the interface of these components! There's not much space, between the hinge tubes and the opposing part. Now, I'm sure most of you are saying "Duhhh".. It wasn't the first thought on my mind, while covering and I had a real fight putting the hinge pins in!
