I am fitting ribs onto spars and it seems to me that thegrease nipple at flap spring area will protrude beneath the finished wing skin as well as the wing root. The wing root nipple should pass through the skin for greasing but the nipple at the flap spring area would preferably be beneath the access panel. I believe I should have welded the nut at 45 degees to straight down? Any input? Thanks
grease zerk protrusion at flap tube bearings
You can buy 45* or 90* grease zerks, if that will help. I am just building those parts now and noticed the Patrol plans don't show grease zerks on those parts. I am thinking of just drilling a small hole and using a grease needle.
DougLast edited by DRLPatrol; 03-20-2016, 09:51 PM.Scratch building Patrol #254
Huntaero, how thick of material does that need? I thought about those and like the idea but was afraid they would stick though on the inside. The spot we were talking about is only one layer of .058 tubing. Where is a good source?
Doug
PS. I should have looked closer, looks like you got them from Aviall?Scratch building Patrol #254
Those are very interesting. I am not really familiar with any other fitting other than the standard zerk. What attachment on a grease gun do you use to grease with these fittings?Originally posted by huntaero View PostHere is what we used on our bearhawks NAS516-1A fitting drill a 1/8 hole and drive the fitting in with locktite .John Snapp (Started build in Denver, CO) Now KAWO -Arlington Washington Bearhawk Patrol - Plans #255 Scratch built wing and Quickbuild Fuselage as of 11/2021. Working on skinning the left wing! -Ribs : DONE -Spars: DONE, Left wing assembly's: DONE., Top skins : DONE YouTube Videos on my building of patrol :https://m.youtube.com/user/n3uw
John,
I will bet you use are around them every day and just don't notice them. Look on the back of the angle gear head on your pneumatic angle grinder or angle drill. They use a grease needle(pictured above), screws on regular grease gun or one of these.
DougLast edited by DRLPatrol; 03-25-2016, 03:40 PM.Scratch building Patrol #254
There is the pic of the end of the needle point grease gun fitting in the pic, available at most auto stores. unscrew the nipple fitting on the grease gun and screw the needle fitting on. You push the end of the needle point into the grease fitting and pump the the grease in, the tool also works on the regular Zerk fitting, here is a listing for the tool.
George
