Excellent. And hearty thanks for the detailed reporting!
Hoerner Wingtip Build
Battson--- you mentioned making kayaks---- there is that stuff that Milliken chemical produces that is being used to make rock-proof Kayak hulls---- It is a pre-preg dual filament
polyethylene matt. You thermoform it just like making an RV canopy -- heat and vacuum (or pressure) . It is strong enough that they make military vehicle armor out of it.
The product name escapes me at the moment--- but I can find it on-line. They will send you free engineering samples.
Tim
Here is a link to the Milliken thermoforming product - called Tegris. Its an extruded PE fiber made so there is a core part of the fiber which has a higher melting point
than the surrounding cladding. The fibers are woven into cloth or mats similar to glass cloth. Once heated- the cores stay in solid phase and the cladding melts and bonds all
the layers together (like it was a resin in fiberglass/acrylic) and creates a solid mass with the cores intact as strength members. It is so strong they have made armor plates
out of it. Kayaks that are rock-proof. Floor boards for Mercedes cars----
Looks like you have to compress it into the desired shape while you heat it. That - I suppose could be done with a vacuum bag...… and maybe heated with steam
from a pressure cooker. Here is the link---
Tim
Originally posted by Gerhard Rieger View PostMore wingtip progressOriginally posted by schu View PostThat looks very strong. What does it weigh?
Stock fibreglass tips are 2.1kg each.
The hoerner wingtips are 3.9kg each, which could easily be made a few hundred grams lighter.
So a total weight increase of 3.6 kg (7.9 lbs).
I am seeing touchdown speeds as good as 30 KTAS with light tanks and two people up, if I really push the limits. So I don't mind the weight increase.Last edited by Battson; 12-20-2021, 04:28 PM.
There are fences like those in the Patrol plans. I asked about those in the past, and I recall the answer being that Bob didn't find they made any noticeable difference.Christopher Owens
I have known all along I would put Hoerner style tips on my Bearhawk. Only question was do I buy the tips from TQFiberglass and install them to fly sooner or go ahead and make them now. Couldn't see paying for those tips, taking the time to install them, just to remove them later. Considered trying to build them out of metal, similar to those on Vans RV-12 but have decided to build them very similar to Jon's but with carbon fiber instead of fiberglass. Appreciate all the great ideas in this thread and others. Will post on progress.
