Are people using any rubber gasket material on side windows when sandwiched between doorskin and support angles or just the plastic window. Im sure i will get a variety of responses?? Thanks again
Side window sandwich seal
I've not seen anyone using gaskets for the windows yet. I have some 1/64th thk neoprene i was considering for the task.
For a different application (shock strut boots) I was looking for some super stretchy rubber (ish). I ended up buying an exercise band off Amazon. I need a heavier one for the shock struts, but wow does it stretch. 15 bucks bought long piece. The material would be good for a lot of different things.
Also google large CV boots.......something like these. You can cut them down alot. Was Simons idea.Originally posted by svyolo View PostFor a different application (shock strut boots) I was looking for some super stretchy rubber (ish). I ended up buying an exercise band off Amazon. I need a heavier one for the shock struts, but wow does it stretch. 15 bucks bought long piece. The material would be good for a lot of different things.
3C0BE8AB-A6FB-4BF7-8DC3-5694784B6AA5.jpegNev Bailey
