I'm installing my exhaust hangers that I got from Clint at Vetterman Exhaust. I'm aligning the tail pipes parallel to the exhaust tunnel just to make them look nice. (although they can be aimed a bit toward the middle) As a result it looks like the exhaust will blow right back onto the landing gear shock struts. I saw that Eric Newton and Russ Erb had made their own exhaust system and both put a downturned tip at the end. Anyone have any thoughts? I haven't found many pictures of other's installations. It would be nice to hear from those that are flying if they like what they did with their exhaust outlets or would do something different. Thanks!
Downturned Exhaust Tips? Aiming Exhaust?
I did down-turned tips. Seems to work well. The landing gear struts are still covered in exhaust residue (lead i guess?) even with the tips turned down 90 degrees to the pipe. The plan was to install them with the full 90 and then trim them back to a lesser angle if i though it was necessary. I figure I'll trim them to the staining on the tip in the photo... IMG_6015.jpg4-Place QB kit #111. First flight May 2022.
IO-470 - 260hp
I was getting some significant CO readings with the exhaust parallel to the tunnel. It was exactly as you stated Paul... Exhaust was leaking through the gear struts. I lowered the stacks and added turned down (22.5 degree) tips that I bought from Clint. Problem solved.
Screen Shot 2022-09-14 at 6.01.47 AM.pngRob Caldwell
Clint's exhausts from Vetterman LLC are perfect in my view. I wouldn't change a thing.Originally posted by alaskabearhawk View PostI'm installing my exhaust hangers that I got from Clint at Vetterman Exhaust. I'm aligning the tail pipes parallel to the exhaust tunnel just to make them look nice. (although they can be aimed a bit toward the middle) As a result it looks like the exhaust will blow right back onto the landing gear shock struts. I saw that Eric Newton and Russ Erb had made their own exhaust system and both put a downturned tip at the end. Anyone have any thoughts? I haven't found many pictures of other's installations. It would be nice to hear from those that are flying if they like what they did with their exhaust outlets or would do something different. Thanks!
Mine are parallel with the tunnel, facing together slightly, and they have given 10 years of great flying. No trouble or maintenance.
