This is an issue I've had with my kit, but I keep putting off dealing with it because my tail feathers are hanging on my shop wall most of the time. I started doing a dry fit of my flying wires and realized I need to address this.
The issue is that when fitting the horizontal onto the front and rear carrythroughs, the front requires incredible pressure to make the pre-drilled 3/16" holes line up.
Out of the box, my carrythrough was 18" long, while plans call for 16 3/4", so trimmed it down per the plans. Fit was a little improved but the horz still requires great sustained force inward to makes the through-bolt holes align. This has the effect of also applying a shear force to the AN4 bolts that hold the front carrythrough on.
I've talked to one other kit owner who's had this problem. They stated that they just kept trimming the carrythrough length back, and then finally tapering the thick wall tubing a little. Bob notes on the plans that you can trim to fit, but how much is too much? I'm currently at about 16 3/8".
It seems like another option would be to slot the 1/4" hole through the angle piece on the fuselage to allow the carrythrough to slide forward just a touch, hopefully alleviating the shear force on those vertical bolts. Those holes were predrilled at the factory. I'm not sure if the tight fit is a function of alignment or the fact that the leading edge of the stabilizer is so rounded, that it actually curves back inward at its innermost.
I'd appreciate some thoughts.
