I was visiting with a friend who has been around the homebuilt industry for 30+ years - mostly around Vans airplanes. He suggested a few places we could help make the kits easier to build for you guys. I would like to mention the areas he felt we could do more and also ask for suggestions.
Basically - the idea is to make the kits easier to build with less worry. Since the kits are not close to the 49% complete the FAA allows, we have some room to do more work on the QB kits. The intention is to do the more difficult or worrisome tasks. Not the easy stuff. I will list these ideas in no particular order to solicit your comments:
1) Delivering the kits with the wings already drilled to the fuselage with the struts and strut ends already drilled.
2) Assembling the shock struts at the factory
3) Drill/ream to final size the engine mount attach bushings welded in the fuselage.
4) Provide the L/G to fuselage fairings. Or at least a pattern.
Those are the few items we thought of and talked about. Those of you building - please give me your suggestions of what could be done with the kits to make them easier to build. We are working on improved manuals which we recognize would be a big help. I look forward to hearing your ideas. Thanks. Mark
