I am fixing something today I did early on. I mounted my control stick assembly on the 4 place as far back as I thought I could. But I had 3/8" farther aft to go, and to line up with the lower aileron pulleys, I need all of that.
I would recommend doing what I am doing now. Carefully check the location of the cables. The pulleys are canted a bit aft on my kit. They are not perpendicular to the fuselage centerline. I need to go as far aft with the stick assembly as I can to reduce friction on those pulleys. Using an AN4 nut as a guide, I will mount the stick as close as far back as I can, which looks like it will make it line up perfect with the pulleys.
I am plugging the original holes now, and will re-drill.
I could feel the friction in those pulleys when I had the wings on and aileron cables rigged.
