Question for you clever folks...
I have the wings on and am just about done mounting the flaps and ailerons. One of the next steps is going to be drilling that torque tube. I'm pretty anxious about it because I am not good at drilling accurately or straight on tubing, plus I'm not sure how to line everything up appropriately before I attempt to do so.
I know I want to drill the arms with the pushrod resting on the padding as if flaps are "up."
How do you locate the other end of the torque tube (the inboard "lever")? and keep it there for drilling? Do I need to install the rigging first? I can certainly reference the plans to see the position it should be in, but making that happen in 3D is more challenging.
How do you drill over your head into a tube freehand accurately? I fully accept that I might be a bit "special" but I had such a hard time with drilling the torque tubes for the trim tabs that I gave up and welded the buggers after drilling more wonky holes than I want to admit. Pretty sure I saved myself a few ounces with that "fix"... :P
Thank you in advance.
