I've always really liked the gullwing-style seaplane doors on aircraft like the Highlander, and plan to build them for my Bearhawk. One problem that is inherent to all 4-place Bearhawks is the steep angle of the struts up to the wing, causing an impingement for the door swing. I'm not a fan of the mouse door, so I see two options, both involved adjusting the height of the door.
1. Build up the door frame so that the entire door is shorter (red line in photo.)
2. Build up only a short section of the door frame, building a complementary cutout in the door itself that meshes when the door is closed (blue line in photo.)
Without the luxury of have wings bolted on, my question is: How much does the lower door frame need to be raised to accommodate a door that will clear in the upswing?
If anyone has done this, it would be great to see some in-process photos. Thanks!
