Plans-built 4-place N873GT (IO-360 angle valve) was put on the scales today: 1375# with an empty C.G. @ 11.6â€.
I made contact with a DAR last week, sent him some of the required papers, and set a tentative date for him to do the inspection of N873GT during the last week in July. I also learned that the FAA now wants the engine run on the ground for one hour prior to first flight; so, today I did 40 minutes of that in 10-minute increments (with 20 minute cooling periods) starting at 1000 rpm and stepping up to 1300 rpm for the final block. I watched CHT carefully; it never got above 300 deg, even though it was hot and muggy. Made adjustments to idle rpm and mixture, and received a “loud and clear†com check from W13 Unicom. All engine parameters looked good. I’ll run it at 1400 and 1500 later this week. Taxi tests and full power run-up will have to wait until I get a “moving status†go-ahead from my insurance company, hopefully soon.
This is always a concern Brooks, balancing the new engine's preference for break-in with the new airplane's preference for flight testing.
Jared is so right! My DAR instructed me to "have at least an hour on the hobbs and a lot of dirt on the tires." Whether the DAR wants it or the FAA demands it, without the DAR's signature, it's not an airplane. Because of issues with my original electronic ignition, I probably had closer to 2 hrs. I don't think it's remotely possible to break in the rings, on the ground. It takes more power than can be cooled. And cooling is most important. Keep the ground runs fairly short. I know it's widely said to never run un-cowled, but you're looking for leaks and stuff that's about to fall off.. Watch the temps and don't overheat! My #4 was pumping oil like crazy by the time I was able to fly. During this year's condition inspection, I fixed a couple of nuisance oil leaks. In the 10 hours since, I haven't added any oil. The moral of the story is to do enough ground runs to be absolutely confident that it will be running when your first flight is complete. If you don't overheat it, it'll break in fine.
Today N873GT received go-ahead from the insurance company for flight status. So, I began taxi tests: burnishing brakes and getting used to ground handling and sight picture...definitely going to have to be peripheral vision until the tail comes up. Did a brief full throttle run-up. Everything stayed cool: max CHT was 275. I’ll do more taxiing this week and then give the DAR a call, hopefully getting certificate next week.
- Likes 7
I flew my LSA again today so here is the report: 30 hrs, flys hands off. I flew along side a Piper Vagabond short wing. yes, he is side by side and he is a rag wing. We started at 80mph he was turning 2400 rpm I was at 2100. Progressed to 100mph he was turning 2600rpm. I was at 2300rpm. He moved to full power 2750, I was turning 2500 along side, I pushed mine full power 2750 and walked away!. Both aircraft have Cont.0-200 both turned red line 2750. Just a little to compare!.. StingerYou do not have permission to view this gallery.
- Likes 6
High-speed taxi tests for N873GT went well yesterday morning; she really wanted to fly as the tail came up...just a touch more throttle would have done it. I stopped at the FBO to add fuel and drew a crowd...lots of questions and positive comments about the Bearhawk. Back in the hangar, I noticed a leaking fuel tank sump valve...bummer. Had to drain the tank, pull the tank bay cover and remove the valve...found a tiny metal sliver under the o-ring...no apparent damage. Put it all back together, added fuel, no leak. DAR may be here late this week. Will spend the time until then going through the rest of the fuel system: gascolator, filter, servo screen. Ditto for oil suction screen. Also need to write out checklists and test card for first flight.
Sorry ... off topic here, but I can no longer find old stuff on the Forum; something has changed (and not for the good)/
I cannot find the Search option using my browser. Clicking on the [search] blank on the upper right gets me into Google and their search results are crap.
Hell will freeze over before I lower myself to becoming part of the Google database.
So perhaps whomever posted a list of various nut-plates required for the Patrol could post it again; I think it was only 3 weeks or so ago that I saw such a list posted on the Forum.
Bergy
Jared switched to Google search because generally it does a better job returning results than the built-in search. However, if you find that you prefer the old search engine, you can still find and use it here:Originally posted by bergy View PostSorry ... off topic here, but I can no longer find old stuff on the Forum; something has changed (and not for the good)/
Bergy
~ChrisChristopher Owens
Northwest, Wisconsin, USA
Finished precision drill guide jig for mounting Grove brake backing plate. Finished exploded view of assembly with four mounting bolts. Perfect fit.You do not have permission to view this gallery.
Finished up my paint job. I hadn't painted the engine cowl because I was concerned that I would need to modify it during the test flying process. I did modify it for better engine cooling so I'm glad I waited. I'm pretty happy with the end results. Not bad for an amateur painting in my garage. I wanted to take it outside and get some good pics but it started raining while we were putting the cowl on. I'll get better pics soon.You do not have permission to view this gallery.
This gallery has 1 photos.Rollie VanDorn
Findlay, OH
Patrol Quick Build
- Likes 4
Looks great, Rollie. I like that shade of blue with the gray. I know you are glad to have that chore behind you. What paint system did you use?
I used Stewarts Systems right from the beginning. I like the fact that you can do it all without much ventilation since there aren't any solvents. The paint can be a bit of a challenge but I found that once I bought the spray gun they recommend things went smoothly. The colors are Stewarts Silver Metallic and Blue Metallic.
