  • Working through first builder’s rudder rigging. The rudder pedals seem to have been mounted too far aft (5” behind centerline of firewall station). With this condition it’s impossible to depress the brake pedal with the rudder pedal at its forward-most travel. Unbolting the pedal assembly and clamping it as far forward on the support plates as possible seems to correct the geometry and result in good brake behavior.
    Before:
    After:
    • Started riveting up the wing skin on my left wing. Think I've got the A/P roll servo figured out on the right wing. Using a base plate from Virgil to prototype in the Patrol along with a Dynon servo wing mount for an RV-6. The servo is the Dynon SV-42 with the extra long control arm which allows for 4.4" of total linear travel according to the spec sheet. Moved the base plate toward the forward wing spar to allow clearance of the control arm to clear the support frame tube of the aileron drive assembly. Base plate required notching on one side to clear wing stiffener.
      AP wing servo mount assembly.jpg AP long arm roll servo side view.jpg AP long arm roll servo.jpg AP wing roll servo.jpg
      • Here is the A/P roll servo mounted in our wing. Similar idea using a plate riveted to the ribs. The pushrod is bolted just below the aileron pushrod. Checking the aileron travel throws at the bellcrank shows only 1" cable each way from center required for full deflection.
        • Slow going, but making progress on closing up the left wing. Was thinking I could squeeze all the wing to pocket skin rivets, but can only squeeze the top skin to pocket skin due to curvature of the pocket skins. The bottom wing skin had to be bucked. Hope I never have to drill out any of the CCP42 rivets called out in the wing manual for the pocket skin to rib fasteners. Also got my pitot mount mostly riveted in. Have two problem rivets that seem to defy proper setting...not sure what's going on. Will reassess another day when fresh.
          Trailing edge and pocket skins.jpg bottom skin trailing edge.jpg Pitot tube mast.jpg
          • Finally finished up the left wing except for a couple "problem" rivets...waiting on a more experienced sheet metal friend to give it a look. There are quite a few more rivets than I was expecting when estimating how long it would take to completely rivet up a wing! Got the AP servo assembly painted, installed and wired on the right wing. Should have the right wing riveted up over the weekend and into the paint shop by end of the month!
            • laying out horizonal stab drawing on build table. making a bending for for the LE tubing out of 2 pieces of hard wood ply wood. About to make the little towers to support tubes 1 inch off of table.
              • Second wing getting riveted up. Can use the pneumatic squeezer for most of the trailing edge
                • Carlo headed to Oshkosh next week while I head down to Tampa to close out my GPS disruption resiliency work at the airport and enjoy that refreshing Gulf Coast mid-summer weather. Did get a few shots of the elevator trim servo mount after the airplane got wings removed and moved back to home hanger for final pre-cover work. Carlo did a single tab versus the split tab plans version based on his experience with his Mustang II which has been operating without any issues for the past 12 years. Will be taking a break later in the summer to do some of his covering work and try to learn that skill-set from a couple show plane pros. You don't know what you don't know until you know it, so only one way to remedy that deficit.
                  Along with the lightening holes to keep weight down on the elevators and rudder and a light-weight servo and mount, removal of the tubing and cable needed for the plans-built elevator trim system helps on overall weight reduction aft of the CG. (Carlo already moved EarthX battery and a couple other systems closer to front seat based on weight savings). Case on engine mount in background of shot borrowed from some cool dude on a short grass strip NNE of Roanoke, VA. Will be returned to owner at the fly-in this year.
                  CC Elevator 4.jpg CC Elevator 3.jpg CC Elevator 2.jpg CC Elevator 1.jpg CC Elevator 5.jpg
                    Nev commented
                    Very interested to hear how your trim servo installation goes - I very nearly did this myself. Should work well and eliminate any trim tab movement during normal elevator use.
                • Forming wing light lens...eventual success. Wings are done, back in the rack and going to paint in a few days. Took longer and more rivets than I had anticipated...like most of my projects
