Control cables are terminated with either an Eye Splice (Nicopress Sleeve), or a Swaged fitting. FYI, Swaged Fittings are professional made by compressing the sleeve of the fitting onto the cable at a very high pressure with a special machine.
I have a few questions, but first the facts.
-The Eye Splice can be made with simple tools in the shop.
-The Swaged fitting is a special, made to order item, from dimensions provided by the builder.
-Most builders use Eye Splices.
-I like Swaged fittings.
-The cable length is adjusted to a small degree with a Turnbuckle to adjust tension.
-All cables must be made to an almost exact length to honer a 7 thread turnbuckle tolerance for initial installation of a cable given in AC43.13.
-The 7 thread tolerance provides a builder with only a 1/4" cable length tolerance.
My questions are;
-How did you measure the length of your cable runs?
-Is there any "Best Practice" or widely used method to accurately measure cable runs?
-Did anyone measure the cable run by threading Safety Wire through it?
-Do these tight tolerances demand that eye splices be made after the cables are installed to get the cable length exact?
-If one used a cable with a 3" stud fitting swaged onto it, would serious problems arise installing it, like learning that it can't be threaded from the strut thru the pulley, and into the wing or fuselage? In other words, is a naked cable end the only thing that can be threaded and installed?
Thanks for your input;
Patrol #303
My questions are;
Patrol #303
