Good evening everybody!
As I continue to research the Bearhawk and its construction, I find myself more and more drawn to it. I've considered a scratch build and a kit and some days I feel confident that I could build from scratch and others I can't imagine not having the security of the QB kit, as I have no experience in fabrication. I consider myself fairly mechanically inclined in that I do some woodworking, nearly all maintenance on my older vehicles, and have avionics experience from the Air Force, however, I have never welded, or worked with sheet metal. My options right now seem to be get started fairly soon on a scratch build and slowly sink money into what will likely be a 10 year project, or save money for the next few years and go with the QB kit. This would be for a 4 place if it matters. So my questions to those of you with far more wisdom and knowledge than I currently possess:
1. Would you suggest a scratch build to someone of my fairly limited experience, or does that open the door to having an unsafe aircraft? In other words, will it be obvious if I mess up on something and provide the opportunity to fix it before proceeding, or is it easy to have significant mistakes and only find out when the FAA conducts their inspection?
2. If a mix of scratch and kit was used, what parts would you guys suggest be saved for the professionals to fabricate and what parts would make sense to scratch build?
3. Assuming a scratch build is chosen, what assemblies would you recommend to start with if the goal is to maintain a practical build process?
4. Where can a tool listing be found?
Those are the only ones I can think of off the top of my head and I appreciate and welcome everyone's input. I may add more questions as answers come in. Thanks again everyone!
Todd
Las Vegas
Todd
Las Vegas
