Right now I am leaning towards a header tank under the front seats. Maybe just under the right seat, with the fuel pumps under the left. I get access to all fuel components, plus the elevator cable adjustment. It is contained within the fuselage, at the strongest place on the whole fuselage.
Header tank design and location
Schu;
I like to make rational decisions instead of what I want. Usually rational wins out. In the case of MFI vs EFI, I think MFI is good enough for me, but I am much more comfortable working with EFI. For me MFI is a box of parts I don't understand. The cost of MFI and dual EI's is similar to EFI/EI.
I think I could have been happy with either, but in the end I am more I EFI's box of parts more than MFI's. Electrically I don't mind a few extra wires as i am good at that part and I will make it reliable. I only don't like the extra plumbing. More precisely, I don't like plumbing!!!!!
I am doing MFI with Bob's original fuel system design due to the issues I am reading about here. My conclusions mirror almost exactly with what schu described. But please allow me to offer what I think might be a reasonable design improvement....way off from Bob's design. So its worth what you are paying for it.
I would feel more comfortable if a +5 gallons header tank was placed aft of the bulkhead with a "Not full" sensor in it, gravity fed by only the aft fuel tank bungs. Highly unlikely that a 5 gallon header tank could be emptied during descent to landing with the aft tank bungs unported....plus it increases fuel capacity. It can have 1 return line running back to it and have a simple on-off fuel valve. it removes fuel lines, removes fittings, and connections. It becomes almost a C-150 fuel system from the operators point of view. Sucking air problem is eliminate, its in a safer location.
Doing pattern work on almost empty main tanks would be no worry. Every landing would fill the header back up in seconds. If one ran the main tanks dry, VFR fuel reserves are in the still in the header.
Note this popular maxim, from Saint-Exupery:
..perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away...
I look up to you who go the EFI, but I am not there yet.Brooks Cone
So Brooks, I take it that you're planning on an electric pump at the rear header tank. That pump will run on low at all times, except high boost for starting - maybe takeoff/landing also.
A tank behind the baggage bulkhead will be well below the engine driven pump, on takeoff. You have to treat such an installation as one would view a low wing, injected aircraft.
Originally posted by Bcone1381 View PostI am doing MFI with Bob's original fuel system design due to the issues I am reading about here. My conclusions mirror almost exactly with what schu described. But please allow me to offer what I think might be a reasonable design improvement....way off from Bob's design. So its worth what you are paying for it.
For those who are using EFI, be sure that its simple to operate without having special operating limitations.
My preference at this juncture in time would be to use a single 5 gallon header tank located aft of the cargo area with an on-off fuel valve.
Bill, its been decades since I last flew a low wing injected aircraft. I sense I may be missing something due to your post...Brooks Cone
I have been trying to figure out how I wanted to do a header tank. One of my assumptions was wrong. Reading some of the documentation for EFII's system, they recommended a header tank of at least 3 gallons, because of fuel heating, if I remember right. I assumed SDS, the system I bought, was the same. Bad assumption.
EFII uses a classic fuel rail EFI delivery. There is a common fuel rail on each cylinder bank, and fuel is returned from a pressure regulator on the end of that rail, AFTER the injectors. The fuel is heated, and that heat returns to the tank, or header tank. SDS uses a fuel divider, similar to the Bendix style I think. The FP regulator is mounted to this divider. Little heat is absorbed by the fuel so a large header tank is not required, according to the owner of SDS.
So a bit of searching for "small header tank" yielded a few results, and also I found the term "surge tank" and "swirl pot". They are very common in racing applications, and converting an old car from a carburetor to EFI, kind of like I am doing. They come in lots of shapes and sizes, 1/2 gallons to 1.5 gallons. Some are just a tank, some with 1 or more internal pumps. A few even have a pressure regulator built in, and the "return fuel" never leaves the tank.
If I can't find one I like I will just make my own. I like the idea of internal pumps to keep it all compact, and most leaks will be internal to the tank. Although keeping the tank itself from leaking (pump mount uses O rings) might be just as hard. If I rolled my own I could probably even put both the primary and secondary fuel filters in the tank. The only external fittings would be 1 or 2 outputs, 1 input form the main tanks, 1 return, and one vent. I could put the whole thing in a very thin CF (1 layer of 5 oz) sump with a drain line to the bottom of the aircraft.
Early on I noticed a lot of High wing airplanes had a header tank. The Bh system is obviously so well designed that I haven't heard of an issue, including feeding a 300hp engine on takeoff at very steep climb angles.
With EFI, without a header tank, the system would be required to flow 35-45 gph, or whatever the pumps are pumping, 100% of the time. The tanks also have to vent that much air. It just kind of makes me tilt my head a little.
With a header tank, the gravity feed only has to feed engine demand. Return fuel goes easily and quickly to and from a header tank. It makes me feel a bit better. Even if the header tank is less than a gallon in size. A gallon is a bit over 2 minutes of fuel at takeoff power, and 4 minutes at cruise.
I will probably start with what is easy, and easy to pass DAR inspection. That is probably a small tank, and the two pumps from SDS.
Hi, My header tank take 2,2 gal and have an 3/8' inlet (top) and outlet (bottom), and two 1/2' vents to each tank,I also fitted a drain at the low point of the tank to clear out any chance of water before flight. ( there should not be any water because the gascolator is fitted before the header tank .The IO 540 Lycoming do not require a return to the header tank, so, I do not have the hot fuel problem. I opted for the 1/2' vents to have the vent of double 1/2' to single 3/8 inlet. This will cause fuel to flow freely even if you un-ported a tank for a moment, it will refill that 3/8' fuel line in no time.
I've beat this drum before and I probably will again. Something about experiencing multiple fuel starvation engine failures due to a design flaw tends to leave a lasting impression.
Sorry for the slight, but relevant, tangent svyolo.
23.975 Fuel tank vents and carburetor vapor vents.
(a) Each fuel tank must be vented from the top part of the expansion space. In addition -
(1) Each vent outlet must be located and constructed in a manner that minimizes the possibility of its being obstructed by ice or other foreign matter;
(2) Each vent must be constructed to prevent siphoning of fuel during normal operation;
(3) The venting capacity must allow the rapid relief of excessive differences of pressure between the interior and exterior of the tank;
(4) Airspaces of tanks with interconnected outlets must be interconnected;
(5) There may be no point in any vent line where moisture can accumulate with the airplane in either the ground or level flight attitudes, unless drainage is provided. Any drain valve installed must be accessible for drainage;
(6) No vent may terminate at a point where the discharge of fuel from the vent outlet will constitute a fire hazard or from which fumes may enter personnel compartments; and
(7) Vents must be arranged to prevent the loss of fuel, except fuel discharged because of thermal expansion, when the airplane is parked in any direction on a ramp having a one-percent slope.
Car4.jpg This is one of those regulations that was written in blood. My blood was almost added to it twice.
I recognize that there are many BHs flying and pretty much all of them do not comply with this regulation nor is it required that they do but it is a design flaw that should be recognized even if you don't plan to change it. It needs to be recognized so that if you ever encounter its failure mode you'll know how to mitigate it.
Attached FilesScratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
Hi guys, I`m no where near thinking about fuel systems and such..I`m not sure if the following is applicable to this... ive been watching some of the Viking Engine(auto conversion) videos....They have 4 or 5 videos about header tank placement and they sell tanks and pumps....Their engine is fuel injected so I thought it might be worth a mention.....I was thinking maybe their tanks could be used with your application and save you some money over general aviation offerings..Last edited by way_up_north; 02-26-2019, 07:02 PM.
I saw them several months ago and made a couple of inquiries. I really liked their "mini-header tank", as it was what I was wanting to make myself. It is very expensive, as are replacement pumps. It is also internally regulated, but not with a reference to MAP, which is what SDS said they prefer. It also has plastic fittings. It is very slick, and I really like it at first.
Walbro pumps are 1/6 the price. I would probably replace one every 5 years/1000 hours as a maintenance item.
I have been impressed with your answers on the forum describing the FI systems in the Bearhawks. so much so, that I decided to join (unlike me) and reach out with a few questions.
I am in Alaska and am in the final stages of completing my fuel injection system. I have a question regarding the header tank and specifically the return line plumbed to the header tank.
I have the factory IO-470 MFI system starting with 1/2 fuel lines feeding a fuel selector of L,R & both, then flowing to a 1L header hank (a small tank!) that we welded out of 1/8" aluminum (pretty heavy duty) and located on the cabin side of the firewall. From there we flow into a "Steve's gasgelator" and then to the CJ electric fuel boost pump and finally to the engine driven fuel pump (that is on the back of the motor and has scatt tube providing cooling. I have the Atlee vented fuel caps (It is a high wing aircraft).
My question is the fuel return line. Right now I am planning returning the fuel to the top of the header tank. My concerns are 3 fold:
1. Will I be pressurizing my fuel system by returning 20PSI fuel (assumption of the pressure of the return line) to a gravity system in a small header tank. Is this even an issue?
2. Do I really need to worry about the temperature of the fuel being returned? I feel like no, because the fuel never hits the hot part of the motor (front of baffling), but I am second guessing this slightly.
3. Do I need to vent this header tank? Or will the fact that the main tanks are adequately vented suffice? I would rather not have to weld another bung into the header tank and then plumb back up to the wing tanks.
Any input would be greatly appreciated!
I am not flying yet, about to do FF testing and weighing the thing.
I originally thought return fuel should be plumbed into the top of the tank. Turns out it is preferable to return it low in the tank, away from in fitting feeding the pumps. This keeps bubbles and foaming down.
1. It shouldn't pressurize the tank if everything is done correctly, which includes venting the header to the main(s).
2. I can't answer that for MFI. If there is significant heating of the fuel, this could be a problem. Cessna 180 series used TCM MFI, and as they used header tanks to return fuel to. One of the solutions to this is a large header tank. I have zero experience with these Cessna's, so I don't know how big their header tanks are. Short answer - I don't know for your system.
3. Yeah the header needs to be vented. I vented mine to one main tank. I will hopefully change this at some point to both tanks, which will then be vented together.
Hope this helps, but keep in mind, Mine is not successful yet!!!
svylo, why does the header tank need to be vented? Wouldn't the vents from the main tanks supply the appropriate venting to the entire system?
Originally posted by Seth Kroenke View Post1. Will I be pressurizing my fuel system by returning 20PSI fuel (assumption of the pressure of the return line) to a gravity system in a small header tank. Is this even an issue?
