A lot has been written and intimated on this thread and I will throw in a few nickels worth.
Just so happens I design fuel systems and components as my lively hood.
So here are a few points of note:
The system that Bob designed is simple and adequate for carb or fuel injected engines.
It works very well when implemented properly.
I have mocked it up in clear tubing to check flow and line refill, bubble formation and flow stagnation. I did this for two reasons: one to
investigate why A Bearhawk engine went quiet
and would not re establish fuel flow.
Two to make sure that in my installation,
IO-470 that fuel flow would be adequate and
un interupted.
Most general aviation aircraft that have a header tank have one for 1 reason.
to meet certification requirement that after engine fuel starvation of running a tank dry
that the engine can restart and produce power
within 10 seconds after switching to an available source.
The Bearhawk system as designed by Bob will go from a dry tank to fuel at the carb in 3
seconds!
Most production FI systems utilize an engine driven pump that is positive displacement pump some fixed displacement / some variable displacement. The pumps are sized to provide Approx 1/3 more fuel than needed
to support combustion. Fuel delivery is proportional to engine rpm. Un used fuel is returned to the “ system “
In most cases the header tank provides a means to capture the excess fuel bypassed and immediately make that fuel available for the combustion process.
I am not utilizing a header. Fuel will return to the left tank. Fuel selector will be R, Both, L, Off.
The primary flight mode is Both. Returned fuel
will level as the fuel seeks cross tank equalization. The fullest tank will have the highest head pressure and will drain the fastest.
Aircraft fuel pumps are not designed to
“ Suck “ and operation in that mode will destroy a pump quickly. Pump inlets should always be flooded by free stream supply.
A header tank is not a requirement but a means to meet a requirement.
Mock up and test your system with clear Tyron
tube to know before you build.
Kevin D # 272
un interupted.
seconds!
Kevin D # 272
