Started following this thread. Very interesting. I'd like to put slotted flaps on our BH but haven't figured out how to have a hinge by the cargo door.
Bearhawk STOL mods
Regarding AoA flap bias, for simplicity sake, in GA, just set it to stall with flaps full, which will be a lower AoA than with flaps retracted. If you approach the calibrated critical angle of attack while clean, you'll then have a healthy buffer before an actual stall.Originally posted by kestrel View Post
The only thing with the fowlers is you'll have a very large difference in the critical angle of attack vs a plain or slotted. Where it's 2-4 degrees for the latter, the former looks like it could be 5-7 degrees according to the graph from the naval aviators book. 7 degrees is massive(considering an aircraft usually has a longitudinal flight envelope of 0ish to 15ish degrees AoA), and might result in stall warnings at rather high airspeeds. Might be worth contacting the manufacturer of your AoA system to see if flap bias is programmable.... if you have fowlers.Last edited by zkelley2; 09-21-2019, 05:44 PM.
Can you share any more info regarding progress on this development?Originally posted by Battson View Post
Someone is doing this at the moment.
The design will allow Airframes AK to offer a standard bolt-on solution for Bearhawk aircraft wings, hopefully they do.
The issue (big unknown) is the pitching moment. Bob has advised that the tail may not be large enough to overcome the increased nose-up pitching forces created by the double slotted flaps. The ultimate solution will be larger tail wings, if gap seals / VGs / greater control deflection don't solve it first.
The plane should be finished and delivered in a week from today. Then they'll be doing paint and probably flying within another week.Originally posted by Shopperly View Post
98.5" of double slotted fowler flaps. I can hardly wait to hear the reports.
- Likes 3
Where is the airplane? In Alaska? Oregon?Originally posted by Battson View Post
This is an A model or a B model?
Does the pilot know how to fly slow well enough to properly evaluate?
VERY interested in this!
Is he installing a true Fowler that actually moves aft or the STOL Performance flap from Airframes Alaska?
Mark or Jono, If you thinks it’s appropriate I’d appreciate the owners contact info. I’d sure love to go see this plane and get a ride when it’s done. He’s likely only an hour or two flight from me.Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
I have seen the flaps installed and functioning.
They look great and function well with the Bearhawk drive modification, to convert the Bearhawk flap handle through to a cub throw.
He has indicated they just bolted straight on, and were easily installed. Of course there are some simple wing skin modifications around the flap pocket too.
One opportunity missed, the modifications to the wing pocket have not created the 'ideal' pocket for the first stage of the flaps. The first stage will probably be un-blown. Though this could be improved at a later stage.
The aircraft is not flight-ready yet. All builders will understand this, 90% finished and 90% still to be done.
It will be interesting to see how they perform.
Yes that is a Bearhawk 4-place, and those flaps are 98.5" long.... They increase the wing area by several square feet when extended, not to mention the camber!!Last edited by Battson; 11-21-2019, 09:46 PM.
- Likes 4
I assume (hope?) that we will learn what the "ideal" pocket for the flaps is? Maybe I'll just plan on building for these off the bat? Looking forward to flight test impressions.https://www.youtube.com/user/fastfox23
Patrol plans #398
This is really interesting news - thanks for updating us!
Are these flaps a 3 or 4 hanger design?
Can you post some more pictures please?!
