Would a sportsman style LE cuff make any difference on the Ribblet airfoil? Does anyone know if this has been tried on a Bearhawk?
Bearhawk STOL mods
It would certainly make a difference (not necessarily better) - but it depends, what are you trying to achieve? If you only care about slow flight, adding camber and increasing angle of incidence are no-brainers. If you also care about cruise speed, maybe not such good ideas...Last edited by Battson; 02-18-2021, 02:35 PM.
Originally posted by Hewko View PostWould a sportsman style LE cuff make any difference on the Ribblet airfoil? Does anyone know if this has been tried on a Bearhawk?
Originally posted by Hewko View PostWould a sportsman style LE cuff make any difference on the Ribblet airfoil? Does anyone know if this has been tried on a Bearhawk?Last edited by rodsmith; 02-10-2021, 11:15 AM.
In essence I agree with Rod.
Both the A and B wings were designed with slow flight in mind, the Cessna was not designed for that specifically. While I think the Cessna wing is pretty good on it’s own the Sportsman cuff offers better slow flight for the guys that want it.Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
So would it be possible during the build to make the standard Bearhawk flap into a fowler flap by attaching a second lower flap pivot point, about 2 inches lower similar to a Maule? And then moving the flap actuating rod attach point correspondingly lower on the flap? The roughly hand drawn in extension point on the attached image shows it better than I can explain it. Is this worth trying or will it introduce problems?
Originally posted by Helidesigner View PostHas anyone tried flap seals? I know the gap is small but air is smaller. Gap seal on my elevator and rudder worked quite well. Tape along the bottom like my elevator and rudder would be easy to do.
I wonder how much difference lowering the flap hinge point below the wing will help, like a Husky or Maule. I suspect a bit, but then we would have to figure out if the wing is strong enough to handle the change in forces.
I also wonder how well your drooping ailerons work. Would you do it again? Any details you can share?
schu
I'll expand on curiosity of flap effectiveness.....
What about Cessna Style flap tracks. You get a true "fowler" flap action and miss out on bumping your head on the hinge that hangs down.
Screen Shot 2021-10-12 at 7.33.34 AM.pngBrooks Cone
Originally posted by schu View PostI wonder how much difference lowering the flap hinge point below the wing will help, like a Husky or Maule. I suspect a bit, but then we would have to figure out if the wing is strong enough to handle the change in forces.
This is my personal favourite to improve Bearhawk performance, in terms of bang for buck.
Completely agree, so much so that I've delayed forming my flap nose ribs while I explore a few options (I otherwise finished all the ribs and was moving on to spars prior to entering remodeling hell). Torsional strength of the wing box was one of my concerns; I don't do structural analysis for my day job and haven't done shear flow calculations since college (now over 20 years ago). A better lifting flap is going to increase the lift on the aft part of the wing as well as the associated pitching moment, so it'll increase rear spar bending loads and overall skin/wing box shear loads. It's good to know that the analysis has already been done for a different flap system that is probably more effective (I'd think a double-slotted flap would have higher loads than even a well-designed single-slotted drooped hinge design). Don't worry, if I do something crazy like actually try to build it, I'll talk to Bob first.
A redesigned tail may get rotten tomatoes thrown my way, but that *may* also be a good "bang for the buck" improvement, particularly if the high-lift capabilities of airfoil/flap system are improved. The Bearhawk tail is beautiful, and the ribs introduced with the Model B makes it even more functional. But, I've seen a lot of discussions on this forum about handling qualities at various CGs - fore vs. aft, and the ability to use the useful load. Even with the profiled tail, I think the thickness/chord ratio is somewhere around 6% for horizontal stab, if I've done it right. My hypothesis is that doubling that (something like the NACA 0012 profile) could yield a little more performance, or conversely require slightly less elevator deflection for trim. It could be more of a problem, particularly at forward CG, if one were to design a flap with higher lift (which would inevitably increase nose-down pitching loads). I'll throw in my usual caution that I have no reasonable analysis result or Bearhawk flight experience to back this up; just what I've tried to read between the lines in the forums and other reports online.
Nick
This is a very interesting discussion.
I'm curious - what issue would be solved by changing the flap design ? Where is the Bearhawk falling short ? Does it need to land slower ? Shorter ? Fly the same approach speeds with more control ? Better "over the nose" visibility ? I've yet to fly a B model and mine will probably be the first that I get to fly, but I'm interested to see if the pitch sensitivity (and pitch trim sensitivity) from the servo tab is still present in the B model.
My point being is that I wonder if there are lower hanging fruit on what is already well proven aircraft before getting into more complex areas such as the flap design. Examples that come to mind are reducing the pitch sensitivity, and increasing pitch control at forward CG/low speeds, ensuring that adverse yaw is limited through correct rigging during test flying, lowering flap bar forces etc.
On the other hand, if it's a case of doing it because it's an experimental aircraft and we need a project, then bring it on !Nev Bailey
The B model still has a servoing trim system, there is no reason to believe it will act any different than an A model. Here is the low hanging fruit: https://www.youtube.com/watch?v=mFQ1VcCiBJo
The high nose angle is reduced by about 50% by a trailing edge lift device, this has been proven by a Utah pilot with a 4 place.
Stall speeds about 2 kts slower.
Stable approach speeds 4 to 5 kts slower.
The nose angle is the main thing - you understand this Nev
In my option the most significant item to improve is visibility over the nose when doing true short field work. The vast majority of us have no need to change anything but there’s a few who would benefit from being able to fly slow and a lower AOA.
We had a conversation about this last year I think. I nerded pretty heavily over it and came up with what I felt like was a pretty simple solution to install a dropped hinge slotted flap..
It’s been a year and I kept bad notes so I’d have to do an in-depth review to recall specifics. At this point I can’t accept taking the plane out of service for something I don’t need.Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
There wouldn't be a massive decrease in stall speed with any of the improved designs. There would be a rather large decrease in ref speed. There would be better over the nose visibility and the ability to fly at slower speeds and touch in the 3 point or 2 point attitude. A max performance landing right now is always a tailwheel first landing.
That all said if you're not using all the performance your bearhawk is capable of and landing off airport at short strips, there's no realistic gain to be had. If you're flying even fully loaded out of 1000ft of grass, there's nothing to be gained. You can just come in at 55 or 60kts and have all the visibility and 2 point landings you want and still not come close to using that runway up.
That all makes sense.
Out of interest, do you guys normally land with full available flap ? I'm wondering what effect it would have if you flew an approach a few kts faster, with full flap so that the drag took care of the extra speed on round-out. Clearly a work-around. But would the few extra kts lower the approach attitude and increase over-the-nose visibility ?Nev Bailey
