Is there any FAA guidance with naming an engine modified to experimental? Looking through lycoming engine designations my engine is now closest to the IO-540D series, has the same rpm limit, compression ratio and spark advance. So I am thinking XIO-540D, or IO540D EXP. Does someone know where to get a new aluminum nameplate made up?
Engine designation and name plate
Maybe call Bob because this is part of his bread and butter.
On engines that have been modified via STC they stamp over or use a vibrating etching pencil to write the new engine model. If I do anything I'll just etch EX at the end of my engine model: IO360KB-EXScratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
Attached is a photo of the data plate that accompanied my 'Bob Built' O-360.
I've been told to remove the factory data plate, if the engine no longer qualifies as Certified. I've also been told to keep the data plate on the engine to maintain the lineage for future parts or information requirements. I'm not sure if the name of the engine is important, but I'd be sure to make a permanent notation in the aircraft records that describes it (as well as you can) for future reference.
Is this something that's required? Do auto engines used in experimental aircraft need to be similarly stamped? I thought the one of the benefits of experimental is we could power our planes with a rubber band if we wanted to and it wouldn't matter.
What you are trying to do is maintain the value of your engine. Documentation here is the name of the game. It’s important to show why the engine is exp. in some cases the changes may improve the engine and therefore its valve. If you just mark it exp. without good documentation a potential buyer may be wary of the engine and possibly with good reason / possibly not but he has no way to know. Also your service will be easier as you will be able to review what was done. Hopefully this will not be an issue.
Originally posted by Archer39J View PostIs this something that's required? Do auto engines used in experimental aircraft need to be similarly stamped? I thought the one of the benefits of experimental is we could power our planes with a rubber band if we wanted to and it wouldn't matter.
Let’s say the crank seal starts leaking. They’re fairly easy to replace, but How are you gonna figure out what seal to get? What if you enjoy the 'Hawk' for 5 years and decide to build another, so you sell this one. The next builder needs to know how to figure out which seal to get.
"Auto engine" you say? I'd think it would be even more important to document what you could about the power plant! Let’s say it’s a Chevy LS conversion and you need some sensor. What year? What version? Think of the possibilities!
To my (admittedly limited) knowledge, what we’re talking about isn’t required. It just might come in handy, though.
My Lycoming came from a certified aircraft via a different experimental aircraft. It is a 1959 O-360-A1A and still has the original data plate even though its been to three engine shops since it was first hung on an experimental aircraft. There is plenty of notations within the log book(s) that make it very clear the engine no longer meets the TCDS. The last engine shop wrote in their entry "experimental engine ..." I don't believe you are required to remove or alter the data plate.Scott Ahrens
Bearhawk Patrol Plans Built
#254
Besides building engines for 25 yrs at Western Skyways, John is an A&P. He thoroughly documented the overhaul to new limits in a new logbook. Included is all the parts invoices. The only thing besides upping the compression and rpm that makes the engine experimental is the non certified accessories.
Originally posted by rodsmith View PostIs there any FAA guidance with naming an engine modified to experimental? Looking through lycoming engine designations my engine is now closest to the IO-540D series, has the same rpm limit, compression ratio and spark advance. So I am thinking XIO-540D, or IO540D EXP. Does someone know where to get a new aluminum nameplate made up?Rob Caldwell
I figurd the Y meant Yippee!
That would make it a (are ya ready?). A YIPPIE-I-O-540......
Sorry..I couldn’t help it...
- Likes 4
I got the number for the DAR I will most likely use. He wants a data plate on the engine with RPM limit and spark advance info. He said XIO-540D designation would be fine. Does anyone know of a business where I could get a custom data plate made? If I make my own and try to scribe it, would probably be illegible.Last edited by rodsmith; 02-12-2019, 02:05 PM.
As a alternative to the local trophy shop try http://www.engravers.net/.
Good place that does good work.
John Ciolino
patrol
