Fuel Pump orientation
  • Fuel Pump orientation
    Does anyone know if the lower section of the fuel pump can be rotated to reverse the orientation of the in/out ports ? It would be much easier if I could have the “in” on the port-side as my fuel line exits the firewall in that vicinity. It looks like it’s been designed to facilitate rotating to customise the alignment but not sure if it can actually be done. (Disregard my label, it’s wrong as per another pump type.)
    Cheers.
    Hey Nev, I would consult the manufacturer.
      LOTS of good info about fuel pumps in this 15 minute Tempest Fuel Pump video. At 14:50 it shows a disassembly of the pump. It seems to me like a qualified shop might be able to around 180 degrees giving you a non-standard part and cause service issues in the future.
      How they work, common errors, and problems, how air in the system effects the pump, all sorts of goodies.
        Ha!!! I see this video was posted on another thread today by another member!!! Interesting!!
      Just watched the video @zkelley2 posted on engine driven (spring driven) fuel pumps. Towards the end, the video talks about specialty tools for disassembly and maintenance. https://www.youtube.com/watch?v=fxT4RAEssnw
        Jinx........
      • robcaldwell
        robcaldwell commented
        Ha! Within 3 minutes of each other!
      I have a busted one in my hangar Nev, for spare parts, if you want to have a look inside one?
      Personally, I would just route the fuel lines to use the existing ports. They are flexible lines and it's easy enough to re-route around obstacles. Use adel clamps as required.
        Thanks Jon. Mike and Pat Scotter gave me the same advice so I’ll do that.
