One of my mentors mentioned using camlocs to attach the top and bottom engine cowls to the firewall, and also to attach them to the nose bowl. While I intend using camlocs to retain the side cowls, I wasn’t sure if they had sufficient strength to hold the cowling in place. I see that Vans often use a piano hinge to retain the cowls to the firewall and themVans instructions show this method.
Does someone have experience with either method that can comment ? Just to clarify, I’m not referring to keeping the cowl doors closed, but the attachment between the upper and lower cowls at the front and aft ends.
Thanks.
Thanks.
