I'm looking for a source and advise for gas struts. I'm thinking I want 5, 2 each for the seaplane doors and one to hold the rear passenger door open. Mcmaster has a good selection but the minimum closing force for any of them is 15 pounds. My doors are carbon compostite, rear passenger door weight is 3 1/2 pounds, seems like a 15 pound strut is excessive. Have not completed the seaplane doors yet but I am estimating 8 pounds. I'm thinking two struts to avoid flexing so that would be 30 pound force for closing. Maybe that is about right.
Gas Struts
Amazon is there we got out struts I think. Jared is right on lifting force. We experimented rather than did math. Our rear passenger door would benefit from a lighter strut but the 40lb strut holds the door open nicely when the wind is blowing. Our seaplane doors aren’t heavy, 10lbs SWAG, and I think we have one 30lb strut on each. A 35lb would likely be better.Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
Hey Rod...this is what gas strut I used:
https://www.amazon.com/C16-08941-C16.../dp/B007MUY76O
And these ends:
https://www.amazon.com/TCH-Hardware-.../dp/B07CZPV826
I have acorn nuts for the ball ends for safety...rounded ends. The struts seem to work just great. If I ever need to change them they are cheap enough to play with. I may even need to go a bit stronger.
http://www.mykitlog.com/users/displa...=280650&row=51
The youtube video mentioned at the end has more to do with how I positioned the tabs than the door or struts.
Paul
A wide range of high quality gas springs ✅ Online gas spring configurator and calculator ✅ Large stock of gas spring replacements ✅ Free shipping in the US.
Get lift supports, gas struts, springs, & more from Lift Supports Depot. Enjoy 1-on-1, personal service & a limited lifetime warranty on select lift supports!
Patrol #30
I bought my gas struts on Amazon. Went through several sets before I got it right.Rob Caldwell
