Grove 66-152
I thought I knew what I was doing... Bleed the brake from the bottom and watch the reservoir until filled. Go to other side, repeat.
It's been almost 3 weeks now and I have spent every single day trying to figure out what is wrong with my brakes... The right brake was grabbing at moderate taxi speeds. I've replaced the right side masters and changed o-rings in the caliper pistons. At Bob's suggestion, I have added 1/16" shims between the back plates and the caliper housing... Still the right side is dragging and grabbing. Yesterday, I changed a suspicious brake line and bled the brakes again. Went for a taxi, and now BOTH right and left brakes are dragging until the plane will not move. Period. Both sides are locked. I literally have to loosen the back plates to get the plane roll just to get her back in the hanger.
I'm thinking:
1) I am not bleeding properly because occasionally I cannot push fluid in. It just won't move.
2). I should take off each line one at a time and blow air through each of them. Reassemble.
Or, 3) I need to replace all of my lines...
I have a new caliper and rotor coming from Grove because I think they just flat are out of suggestions. I have my doubts about replacing a single caliper and everything just suddenly works...
If you have any suggestions, please let me know. I don't care how brutal the thoughts are. I could care less anymore. The weather has been absolutely gorgeous here with blue skies and no wind for over a week now. Mother nature is thumbing her nose at me and I SHOULD BE FLYING!!!!! Instead, I'm stuck on the ground playing with my brake system, daily.
Signed,
EXASPERATED!
I'm thinking:
Signed,
EXASPERATED!
