All theory I've read (Nasa studies) says treat the Exit size as a cooling throttle. So that plus the tightness of the baffling primarily controls the CHT. Nosebowls not so much, but a poor design will not flow well.
I will echo and validate what Glenn and another Patrol Builder advised me... A bottom cowl that has some extra room at the exit tunnel for airflow out of the cowl had sufficient cooling with no lip. The Patrol was based in the south. I wish I had some dimensions. Lycoming wants a pressure differential of 5" of water across the cylinders. Measuring the pressure drop is pretty simple, tools are fairly inexpensive, and it seems that very few do it.
Glenn, what is the measurement of the opening between the top of the tunnel and the bottom cowl in your Four Place?
Hi Brooke,
Missed this as I have not been looking much lately. The tunnel was made to the drawings. The drawings and airplane are a half hour away so someone may be able to give the numbers quicker.
The cowl at the tunnel follows the natural flat curve of what the firewall would be. The back edge overlap of the cowl is the same for the full perimeter of the firewall. The exhaust pipes are close to the sides of the exit and are never below the cowl line. It could be that the cowl overlap on the fire wall may have an eductor effect in that the air passes clean over the exit opening. The air going over the cowl at the exit could cause a low pressure to draw cooling air out. We concentrated on making the metal baffles fit tight to the engine and then seal the aluminum baffles to the cowl and nose bowl with the rubber gap seals. The rubber is tight and we have to be careful to tuck it in when we put the cowl nose bowl halves on.
Whee hit it on the head with the Continental engines. The Cont IO-360 has all the air intake and fuel injection systems on top of the engine. These systems are not hung under the engine to frustrate cooling air flow. The open air channel down the middle underside is impressive from the nose bowl to the exit. The taper of the underside of the cowl expands front to back so as the cooling air volume increases going back to the firewall there may be no pressure restrictions to the air passing through all the cylinders so the underside pressure may be uniform. The underside of the cowl tapers quick and is relatively flat with a very gentle curve across the under cowl. There is no air intake on the lower cowl to alter the air passing so it is a clean air flow down the cowl. My partner wanted to emulate the underside profile of the Mountain Goat aircraft as he thought the shape did a lot for take off lift. (
http://avstop.com/news/goat.html ). This is pure conjecture. It may be that our cowl has the large relatively flat for the air to accelerate down the length of the cowl to create a back draft or vacuum effect as it passes over the boot cowl opening. The under cowl air flow is at a down angle projecting away from the airplane so it could leave a low pressure in the boot cowl opening. We softened the boot cowl exit with the tear drop profile wrap on the firewall corners to aid laminar flow.
I read all the information I could find on cooling as well as the Bingelis books. It is not a science based design but more an instinctive design of using principles that would work with our cowl set up, to seal the engine top side to perfection, promote as much upper engine pressure possible, maintain as clear an exit channel down the underside as possible, have the exhaust tips with a slight elbow but not hanging in the air stream, and modify/fab the MC3A nose bowl for cooling to facilitate the steep under cowl angle. Cross fingers, collect lucky horse shoes and run it as we built it then modify the cowl if need be to add cooling. My partner wanted to supplement cooling but I wanted to hold off and not solve an issue where there may be none. So somewhere between the Continental engine and amazing luck the cooling all worked out. Have to win one once in a while.
Looking at Nev's photo that started this thread. His cowl looks so good up to the point that the cowl was cut out so that the air flow out of the cowl is interrupted and becomes inefficient. The altered cowl removes the cowl's ability to create negative pressure in the boot cowl outlet. The lip further frustrates exit air . Nev's exhaust goes straight back to look very good to me as it leaves a lot of boot cowl open. It may be that if the lower cowl overlapped the boot cowl the same as the rest of the cowl that the engine may be close to efficient cooling. Could possibly even put a slight extension on the lower cowl over the boot cowl to artificially expand the opening area and create more eductor or vacuum effect without affecting overall aerodynamics. It is all dependent on the engine characteristics, how well Nev's upper engine is sealed and the attention to laminar flow and clean flow in the cowl including the firewall.
