Bush and Mountain Flying book
Builders Log - We build planesTags: None
I haven't, but since I've become a more visual and less literary guy in modern times, I do love this video series below. I must have watched it a hundred times.
https://www.youtube.com/playlist?lis...iRRhwzlQMxTUCv
It's more technique than anything and probably doesn't contain the content that's in the book you reference. But I'm a fan.Christopher Owens
- Likes 3
Nev
CC’s book is pretty good, but far from best on mountain flying.
Check out Amy Hoover and Dick Williams’ book, Mountain, Canyon and Backcountry Flying
It is the best in my opinion, and I have read every one I could find.
I am drinking coffee and headed up to scout some goats this morning in my buddies Cub, but if you want a more comprehensive list let me know. Order them all at once and save shippingLast edited by Utah-Jay; 08-26-2022, 11:00 AM.N678C
Ok, here are the books I felt had at least some good info. Obviously some are better, several have overlapping info which serves to reinforce it’s importance
Best
Very good
B6374B28-86E1-4E33-9B33-84D0DB1AC6E8.jpg Good
And yes CC’s book
DB2EAE67-A76A-4985-B980-D41C3E4F0D47.jpgN678C
Here are some nuggets I got from the books, I carry a laminated copy in my plane.
Take-Off and Landing Calculations
Density Altitude
3% loss of performance per 1000’ DA
Headwind- A wind of 15mph will decrease Landing Distance by 10%
Tailwind - Add 10% landing roll for every 3mph tailwind ~10mph Maximum~
Gradient Effect on Landing- Each 1% of slope will effect about 3% of landing distance
- Each 1% of gradient is about equal to 10% change in effective runway length
Unimproved Strips- Add 20-30% for Long Grass (longer than 4”)
- Add 45% for Sand
- Add 20-75% for Mud or Soft Surface depending upon severity
71% of Vr speed should be reached by the mid-point of the runway
Gross Weight
1% increase in Gross Weight will increase Take-Off about 2%
- Likes 4
It's great to have an airplane that can takeoff shorter than land but it's quite easy to get stuck anyways. One time I landed on this strip close to Elba. It was sloped uphill with a power line at the high end. A solid breeze was blowing downhill. This made landing it easy but the uphill departure with obstacle made it very dicy for leaving. I ended up waiting for the wind to turn. Luckily this took only a couple of hours and the locals took me to a nice lunch place where I ate scorpion fish tortellini for the first time. If the wind would not have turned the same day it would have been very handy to run some numbers and then do some mid-point speed tests. Generally I find the mid-point speed check very practical. Use it and variants of it a lot when glider towing on short strips.Last edited by noema; 09-01-2022, 06:59 AM.
I made a Take-off & Landing distance calculator for my iPhone which so far is surprisingly accurate. Its main value is for hot/ high/ tailwinds. For most people it's probably a bit academic (I quickly got used to estimating it) but I still find it useful to get me thinking about these airstrips before launching into and out of them.It's great to have an airplane that can takeoff shorter than land but it's quite easy to get stuck anyways
I bought CC’s book after hearing him speak on the subject at OSH. His talk was great. I haven’t read the book yet.
I went down a rabbit hole a bit on the subject in YT videos and recall some great information and importance of understanding climb gradient vs climb rate. It is interesting to realize that a ‘high-powered’ airplane like a big engined C-180 may have a lesser ability to gain vertical vs horizontal feet because of ground speed as opposed to a Cub.
Aviation has a lot of "isms" in it. Some modern, some holdovers from 70 years ago. The science and math never changed, but how it was taught and characterized are stuck in various older time periods. Building airplanes has been a continuous process of improvement. Flying them? Two step forward, one step back. Sometimes stuck 5 steps back.
