Twice now I've found my brake calipers to be slightly loose and allowing some movement. This is where the caliper fixes to the lower landing gear around the axle. There are 3 bolts installed there, which is probably less than optimum, but at the time I couldn't see how to add more. The access is quite tricky in that area.
Does anyone have advice on how to solve this issue ? Part of the problem is that gain full access (and tighten the bolts) the wheel and brake needs to be removed. Has anyone welded the nuts in place - is that even an option ? Or Loctite ?
Any advice appreciated.
