I've recently clocked over 500 hours on my BH. One thing that has been a recurring theme is getting rock and stone damage on the underside of my elevators - both sides. Given that it's a bush-plane, and a very capable one at that, my purpose for building and owning it was to get out "off-piste" and explore the backcountry. So while I make every effort to look after the airplane and keep it in great condition, I also made a conscious choice to use it as I intended and that includes some gravel bars and on occasion higher rough strips that by their nature have a large quantity of sharper rocks of all sizes.
My question here is, do any of you know if take-off and landing technique has an effect on rock damage to the empennage. For example, I used to keep the elevators full forward to help raise the tail clear of the ground. However this obviously presents the elevators squarely in the way of flying rocks. So for the past couple of hundred hours I've tried to keep the elevators neutral when operating on rocks - however it hasn't made much difference. I've eliminated heavy braking (on nearly all landings) and have always performed rolling take-offs. With a tailwind, I'm very careful with ground handling and thrust application especially on loose surfaces to avoid picking up rocks in the prop vortices.
It's possible that getting this type of damage is simply "par for the course". But if anyone has any good suggestions then I'd welcome sharing them here.
