Hey Guys,its been awhile since I have made a progress report. I have been busy working on the engine compartment. My plan is to get the engine cowl installed and the induction system working. I plan to get the engine running and all the support systems for it assembled, Once I get the engine cowl and the engine running I plan to take it all apart and cover everything. Here are some pix of the engine compartment so far. There is still lots of work to do, Im about as far as I can go until I get my baffle kit. It a special kit made just for the William Wynn nose bowl and the corvair engine. Got a ton of pix, I hope you all like them.
DavzLSA progress
Hey guys, I have more progress to report. I finally finally have all the engine control in their final form and dialed in. I even have the cabin heat box dialed in as well. I am waiting on my engine baffles from Jim Weseman in Florida. He makes a beautiful set of baffles and im looking forward to getting them. My goal is to have the engine running by the end of the month. The only control I dont have finalized yet is the trim control. I decided to change from the wheel I had to a simple lever, its also lighter. I know its taking me forever but that's what happens when you have to engineer as you go along. Im sure in the kits most of this stuff is already figured out and designed. I have pix of all the engine controls and will have pics of the trim controls when I get it in and working. Hope you like the pics.You do not have permission to view this gallery.
This gallery has 8 photos.
Hey Guys, here is davzLSA panel 2,.0. I need to label the switches and add a usb port. I rearranged some of the instruments and I think it leaned up pretty good. I am currently working on an avionics tray. Ill have pix when I get it installed. I think it is unique.I have not seen one like this one will be. I have a set of engine baffles on the way so when I get them I plan to get the electrical system installed and fire up the engine. I plan to make a video of it and post it here. Lots of good stuff to come.You do not have permission to view this gallery.
- Likes 3
Hey guys, I have some more progress to report. As seen above I have my instrument panel put together, I have also fabed my avionics tray and have attached some boxes and fuse blocks. I have the baffle kit finally and have assembles it on the engine. I have painted the baffles. I still need to wire everything but im waiting on some other supplies to make a good wiring harness.You do not have permission to view this gallery.
This gallery has 14 photos.
It looks like you are making some good progress Dave. I'd like to point out something on your fuel line routing. You have brought the rear fuel line down the B pillar all the way to the floor before going forward. Keep in mind that the goal is for the fuel line to be continuously going down all the way to the fuel valve so that the gascolator is the lowest point in the fuel system. Your routing would probably meet this goal with the aircraft level, but with the tail down on the ground, the fuel line will be going uphill as it goes forward along the bottom longeron. Take a look at page 58 in the Bob's LSA book that came with the plans. He shows the fuel line turning forward, but continuing down as soon as it gets below the door. This provides enough of a downhill angle that it is still downhill even if the tail is on the ground.
I like your avionics tray setup - great idea. If I was building again I would add a couple of dozen tabs in strategic places over the airframe. I always needed tabs that weren't there. They're easy to cut off, but harder to add after the fact!
Hi Dave, I have spoke to Bob about the way I have my fuel lines routed. Both lines go down to the floor before turning forward. He said as long as they route down the A and B pillar to the floor and T-off where I have them at the fuel valve then into the gascolator that it is safer. My lines actual t-off near the fuel valve. I wanted to have the T-off at the tank and just have one line going down the B pillar. Bob said he has tested this configuration and said it was not safe. So im going to do what Bob recommended. Thanks for your comments. Please keep them coming.
Hi Dave, I reviewed the build manual like you suggested and now understand what you were talking about. I changed the routing to conform with the manual. It makes for shorter fuel lines and that route solves other interference problems I was running into. This is the reason I am posting all my progress so some one can point out anything stupid I might do so I can fix it. But Bob did say going straight down to the floor before going forward would work, but is causes too many other problems to be practical. Thanks for pointing it out.
Hey Guys, I have an update, lately I've been working on a new set of seats. I didn't like the first ones I built so I build two more. Presently they are at the upholsterers. I will have more pic when they come back for there. So here are the pics. I built the pilot seat so that the back can lay down to make it easier to get to the back seat. They back seat bolts into the frame in the back. The frame is per the plans, I just made a real seat that attaches to it. When I get the seats back I'll have pics.You do not have permission to view this gallery.
- Likes 3
Hey Guys, I have progress to report. I got my seats back today from the upholster, they are beautiful and very comfortable. I hope to spend long hours in them enjoying the view from 5000 feet. I also bolted my prop up for the first time. I just wanted to see what it looked like on the plane. It still needs to be pitched though. So it not the permanent install yet. I got pix so enjoy.You do not have permission to view this gallery.
- Likes 7
Originally posted by davzLSA View PostHey Guys, I have progress to report. I got my seats back today from the upholster, they are beautiful and very comfortable. I hope to spend long hours in them enjoying the view from 5000 feet. I also bolted my prop up for the first time. I just wanted to see what it looked like on the plane. It still needs to be pitched though. So it not the permanent install yet. I got pix so enjoy.
Carry on!
