I'm asking some open ended questions that may only produce more questions, but I really don't know.
For the Yamaha, it seems like the installed weight is 180 pounds, as best I can tell, with 150 horse power. This is a popular choice in some other STOL designs including the Highlander and the Zenith planes. Steve Henry has a nice firewall forward package including the wiring harness and prop for $23,000.
Another, more radical choice is the Verner Radial. Weight is around 200 lbs wet IIRC. Max power is 124 hp at 2300 rpm, 103 hp continuous at 2000 rpm and 287 ft lb or tongue at 2200 rpm. I"m sure the radial will hurt cruise but what do you think about take off and landing performance? http://scalebirds.com/scarlett-7-series
I'm looking to get a LSA in the air as light as possible with a minimum of instruments for STOL flying. I would also like to get the most bang for my buck in the engine area.
I'm having a hard time getting good numbers on other conversions and rebuilds. If I could do something else for say half the money of the options above, I'd be willing to trade some performance for cost.
How much does it cost to rebuild a suitable Corvair? I understand that some of these engines can make 130 hp, correct?
How about rebuilding an O-200 or the C-85 like Mr. Barrows did on his LSA?
Sorry for the rambling and thanks for the help.
Paul
Paul
