I am putting my inspection hatches on. I just completed the last one (the big one by the aileron bellcrank) and I see that when the screws are in around the perimeter, the cover has a “puffed out†appearance. I put a straight edge on it and it bulges out about 5/16†in the center. The other smaller hatches all seem to be flat or slightly concave, by about 1/16â€. I can live with them.
I’m not sure what the culprit is. I’m using the nutplates from Avipro (k1000 I think). I match-drilled the holes in the inspection cover frame to the cover itself, then dimpled both for 6-32 100-degree countersunk screws. I noticed that the dimpling caused a lot of distortion in both the ring and the cover, which took some effort to flatten out (mostly). Then I dimpled the #40 nutplate mounting holes in the frame, flattened it out again, then drilled out the screw holes to15/64 in the frame so there is clearance around the nutplate screw hole. Then I flush-riveted the nutplates on. I match-drilled the cover frame to the skin and dimpled for flush rivets. The frame riveted down nicely under the skin. I do see that my screw holes in the cover don’t exactly match with the nutplates anymore. Some are off by 1/4 of a hole (maybe 1/64 to 1/100 of an inch). I tried to widen those out a bit, then screwed the cover on. It goes on but as I said, it’s buckled into a puffed shape.
I want to get this cover to lie reasonably flat, by cutting and or putting stiffeners in if I must. I’m not sure how to proceed. I also want to improve my technique to allow for the distortion caused by the dimpling, or eliminate any error in mounting nutplates, or whatever else is causing the holes to line up initially but not once riveting nutplates on and dimpling is completed. I’m using a nutplate as a jig, with a pan head screw tightly clamping the nutplate onto the frame through a #30 hole in the frame.
I have some .032 material which I could use to make another cover with, or I could use this one for the other wing(not yet started) and use the other blank cover for this hole. However, I’m doubtful I could get the holes to line up perfectly now that the ring is solidly riveted to the skin. Is it possible to accurately mark through from the back of the nutplate onto the cover and then drill?
Any advice is appreciated. Thanks.
