Group: This is me thinking/observing cruise performance....Cruising at any altitude.
One Observation and a few questions.
- Whats best engine setting for cruise?
- Define your goal.
- Max efficiency.
- Do you want to fly slow?
- No
- Going fast requires more Fuel Flow. How much fuel do you want to burn at this altitude?
- Lets say 8 gph today.
- Then Experiment! Try different RPM's, MP & mixtures at 8 gph. Then discover the setting that maximizes TAS while staying with in the boundaries of the Lycoming power chart (Max 5" over square)?
- That chart lets me go down to 1800 RPM. For example, 5" over square is 23"/1800.
- Thats what I mean.
- The other day I had a short flight at 2500'. At LOP & at 5.4 gph I improved my cruise speed by 3% by slowing the RPM from 2200 to 1900.
- LOP Question....
- Is the LOP calculation that my EI Engine Monitor that I did at 2200 RPM still valid if I set 1900? Do I need to re-sweep the mixture to re-find Peak EGT?
- If my EGT stays about the same, is my LOP calculation is still accurate?
- Oil Consumption
- I think my oil consumption goes up when I slow down the RPM to 1900 or 1800 rpm.
- Max Efficiency may (key word) have a cost of increased oil consumption...needs more research.
- Do others see higher Oil Consumption at slower RPM's in parallel valve Lycoming engines?
- CHT's and Oil temps drop when slowing RPM down this much.
- Is it worth 3%?
