I got my engine tuned and did my first taxiing yesterday. It was exhilarating to feel the plane move on its own power after sitting in pilot seat for over a decade and dreaming.
I was expecting it to go straight, initially it seemed to, but as soon as I tried to steer it with a gentle press on the left brake pedal, it did start turning left, but would not straighten up. Had to run back to the hangar to get the towbar and straighten the tailwheel.
Suspecting the right brake to be ineffective, I checked the fluids and even raised up the right gear and manually confirmed that the right brake was working fine. In spite of this, I am unable to straighten it out once I start turning. And it only turns left.
I have a tundra lite tailwheel with T3 dual shock suspension. This does not have any steering and is supposed to be steered with the brakes.
Here are things I checked so far:
Both wheels turn smoothly when jacked up, and both the brakes are working ok. The tailwheel also turns both ways without any interference.
I have never taxied on a free castering tail wheel before, not sure if I am doing this right.
Thanks
Hari
Thanks
Hari
